jpet
Jan P.
That's just it. My past experience, and other local drivers with sigs, and my 'test' against a identically configured P85, driven in identical circumstances and weather, indicates a minimum 15% difference, that's why I'm taking issue with it. On average, I think most people drive MS as if they are enjoying it (hence 220Wh and not 200Wh as an average) - I do too, but with lots of long distance driving, I drive to arrive.
I understand you're taking issue with it, I would too. Wheel alignment would be the first thing I would have Tesla take a look at. This can make a significant difference. If there is such an issue, you should also experience excessive and/or uneven wear of your tires but it will take a couple of 1000 kms before you can see this.
What you can do yourself is double check your tire pressure: 45 psi (3.1 bar) for the 19" and 42 psi (2.9 bar) for the 21".
PS - Have you compared your Battery Survey with data from the US/Canada lifetime efficiency thread? I seem to recall 330Wh/mi down to 300 was a standard range for my area, flat terrain.
The sheet was originally started over here in Europe, but now it is global with 8 participants from Canada and 40 from the US. I wish more owners would use it because it gives us good statistics we don't get from Tesla. Location is quite relevant since speed limits and temperature vary between your region and mine. This is reflected in the statistics:
