brancky3
It would be an absolutely terrible wheel design if you couldn’t reach an axle nut with the wheel on. That’s a hard requirement.A 32mm socket does fit through the EV01 center hole, so, undoing the axle nut should be very doable.
Ya know, I kinda like this idea. Would be a fun meetupI have an even better idea than all the rest. How about we *all* road trip to @martyb126? Bring your tools. I'll order the pizza (like 20 trays)... and we get this job done once and for all.
I'm only half joking.
There have been a few suggestions similar to this one. I'm thinking part of the problem is that it may bind when pulling on one part of the wheel. This solution would put more force against the area that is binding. Otherwise driving the car around with the lugs loose would likely have popped the wheel off already.What about taking a scissor jack and a long piece of wood and using the sissor jack put a piece of wood in between the tire and sissor jack on one end. Then a long piece of wood up against the wheel on the other side of the car. As you raise/open the jack it puts pressure against the wheels and may pop them off the hub
OP should send this thread to Elon. You have just found a way to eliminate lug nuts as a cost & weight item. Cold-welded rim installation. Also theftproof!There have been a few suggestions similar to this one. I'm thinking part of the problem is that it may bind when pulling on one part of the wheel. This solution would put more force against the area that is binding. Otherwise driving the car around with the lugs loose would likely have popped the wheel off already.
Press fit car wheels. You joke, and I want to laugh, but instead I'm just scared.OP should send this thread to Elon. You have just found a way to eliminate lug nuts as a cost & weight item. Cold-welded rim installation. Also theftproof!
Quick... delete this thread before Elon sees it!Press fit car wheels. You joke, and I want to laugh, but instead I'm just scared.
Haha. There is an instructable for everything.Remove a Stuck Alloy Rim Without Damage
Remove a Stuck Alloy Rim Without Damage: If your alloys are like mine they corrode a bit and are quite hard to remove, the natural instinct is to get a lump hammer and start pounding - STOP - you will mash up your alloy (don't ask me how I know that) Let me show you a better way.www.instructables.com
It's the same trick for getting unstuck like in mud and some dude even did it with an igloo to wash his cloths.Haha. There is an instructable for everything.
They are not! Due to the holiday, I’ve been unable to spend time, but I’m out of ideas and energy. I’m dropping it at a shop next week who says they’re willing to spend some time trying, but if they’re not able I’ll ask them to cut them off. If they don’t want to be responsible, I’ll be buying an angle grinder and try to slowly get one them off. Concerned about breaking something else and needing it to be towed, but fingers crossed the shop can figure it out.Update please..... please tell us they are now off
