MPH of regenerative braking?
Discussion in 'Model S: Battery & Charging' started by Patrick W, Apr 16, 2015.
  1. Patrick W
    Patrick W Active Member
    SLC, UT
    If I understand things correclty "MPH" means how many miles one can get from an hour of charging? Correct? (with all of the abbreviations used on the forum it would be handy if there were a "Definitions of Abbreviations" FAQ) :)
    Is there a rule of thumb for the MPH resulting from regenerative braking?
    Put another way, if one is coasting downhill and using regenerative braking for a given period of time can one estimate how many miles the braking puts back in the battery during that period of time?
  2. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    10kW is officially 30MPH of charging speed, so just look at your regen meter and see what you get. If you hit the peak of 60kW, then your regen charging is about 180MPH for whatever brief period you can sustain that.
  3. Patrick W
    SLC, UT
  4. jerry33
    Texas
    Because the search function at TMC is pathetic. To find anything at all you need to use advanced search (the simple search box never ever works, and never has), but you can't use a string in quotes to narrow the search, and usually it takes multiple tries to get the search term it likes.
  5. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Agreed. for such a tech savvy group, why does the search box suck so much? You could type in Tesla, and I bet it still can't find it.
  6. LetsGoFast
    LetsGoFast Active Member
    Virginia
    The forum software is written by a third party, like basically every discussion forum on the net. The software used here (vbulletin) is good for what it does, but not very good at searching. Some of this is actually a problem with MySQL, which is where your messages are actually stored and some of this is because search is just a side function for these kind of programs.
  7. jerry33
    Texas
    Agreed, but it doesn't change how well search doesn't work :)
  8. brianman
    brianman Burrito Founder
    EV Acronyms - Tesla Motors Club - Enthusiasts & Owners Forum
    - - - Updated - - -
    The "simple" search you refer to is, presumably, the search field next to the magnifying glass that you can do with "type + 1 click". The's google search. Apparently those guys don't know how to write a useful search engine compared to the authors of "Advanced Search". ;)
  9. Patrick W
    SLC, UT
  10. ra-san
    ra-san Member
    San Diego, CA
    You'd think they were a bunch of yahoos!
