Vendor MPP At Global Time Attack Superlap With A P3D! Nov 8/9
Discussion in 'Model 3' started by MountainPass, Oct 31, 2018.
  1. Gavyne
    Gavyne Member
    SoCal
    Which Group are you guys in? The livestream only shows which group is driving at each given time.
  2. Daniel in SD
    Daniel in SD Active Member
    San Diego
    Here's the timing data: Session
    Goal should be to beat the Enthusiast RWD cars too!
  3. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Hey Guys!
    Thanks so much for the support, and sorry for the lack of posting so far today.
    Great news, we got Track Mode! It's awesome. The best feature by far is that Track Mode cranks up the compressor and sheds heat from the system, even when charging. I can't explain how powerful this is. Even when on track we can attack for 2-3 laps, then do one cool down lap, and then attack again.
    The cooldown time allows the car to fully chill the battery and motors resulting in the ability to attack again. Also on warm-up laps where on a standard Model 3 the motor and battery would still build up some level of heat, track mode works hard to allow the car to be ready to go when power gets turned up.
    Buttonwillow is a very cool track, very challenging with a lot of compressions and aggressive curb hits. I really enjoy the flow here!
    I've been doing the driving today and despite this being my first time here, we've already set the fastest time for this class ever since the tire rule was updated from 140 to 220. I did a 1:59.5xx in the last session during the heat of the day, so I'm confident a 1:58 will be possible however I likely won't be running tomorrow so we may not know for sure. I'm still finding time on the track as well. I'm sure Cameron will lay down a super fast lap as well. My original goals of a mid 1:50's lap were pretty optimistic!
    Here's a quick clip from Instagram of this morning of the car on the hustle:
    Mountain Pass Performance on Instagram: “Global Time Attack first practice session. Doing some setup work and we'll be at it again! #globaltimeattack #mountainpassperformance”
    And some photos:
    • Love x 10
    • Like x 4
  4. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    I watched the last session live and it's looking good! Best of luck tomorrow and post more in car videos!
  5. kbecks13
    kbecks13 Active Member
    SoCal
    Super impressive! I was out there a few weeks back (see photo) with Tesla Corsa and me and the other P3D's could only get 2:14 to 2:18, ish. Mostly stock, though one guy had wider/stickier tires.
    Definitely a very fun track and pretty throttle intensive for a Tesla, we were getting power limited only ~5 minutes into a 15 minute session and taking a slow lap didn't really result in much cooling. Great to hear that a cool-down lap is effective at getting the car ready to go again with track mode.
    I think i'm going to have to visit again with Speedventures in December ;)
  6. Pied
    Pied Member
    Bay Area, CA
    That's a pretty good time. I haven't been to buttonwillow for a couple of years now. Fastest I did was 2:19 in a 200hp Genesis Couple with wider tires. My times got slower as the car heatsoaked.
  7. Lucky13
    Lucky13 Member
    San Mateo, CA
    Is power consumption much more noticeable with track mode? Meaning it must drain battery much faster than with out it on.
  8. JeffC
    JeffC Member
    Silicon Valley
    Track mode presumably allows larger slip angles, uses individual wheel braking to send torque to different wheels, uses slight amounts of front or rear motor torque changes to add or remove torque from particular wheels, and uses more air conditioning to cool the system. Those all do require energy, but only a small fraction of the amount used to move the car. (Ironically the air conditioning may be the highest power draw.)
    If so, any difference in battery drain due to track mode are probably relatively minor.
  9. XBS9
    XBS9 Member
    Los Angeles
    Any screen shots of track mode settings? How any power settings or just cooling? Seems like it trying to utilize torque vectoring by braking individual wheels.
    Looks like a great event, wish I could have made it!
  10. agarabaghi
    agarabaghi Member
    Orlando
    stream is back up. is the tesla gonna be racing again?
  11. Daniel in SD
    San Diego
    Someone ran a 01:59.188 in the Enthusiast AWD class. Looks like tough competition out there!
    Is there a 220TW tire that everyone else is running?
  12. Gavyne
    Gavyne Member
    SoCal
    They're up on live stream. Looks like Group D.
  13. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    what's the best lap time so far for the day?
  14. agarabaghi
    agarabaghi Member
    Orlando
  15. Odiemac
    Odiemac Member
    Hayward
    Sasha was driving yesterday doing development testing, today I am working on setting a lap. The class rules requires owner of car to set official lap times. But the car can definitely do it!
  16. hd-2
    hd-2 Member
    Chicago
    How does it feel with the stronger regen into corners? Is it much higher regen compared to non-track mode? I turned on Track Mode right after I got it last night (just in the garage, I'm not anywhere near a track to use it yet) and I definitely heard the BMS kick into overdrive cooling down the battery.
  17. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    good luck out there. The track looks pretty dirty and slippery.
  18. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Sasha beat that time this morning, but it won't officially count because he isn't the registered owner! We are doing everything we can to help Cameron have the drive of his life!
    • Love x 2
  19. Odiemac
    Odiemac Member
    Hayward
    Track mode works great. I wouldn’t say I necessarily notice the regen on track, since on track you’re either on the power or on the brakes. You do notice the motors and stability control working with to pull you around the corners, though. It really helps improve lap times for non-Pro drivers.
  20. kbecks13
    SoCal
    Hey, that's me! I'm super excited to compare track mode on vs off with the same car and see how much it helps me. Did you do any comparisons?
