MPP AWD/Performance Coilover Impression and Installation
Discussion in 'Model 3: Driving Dynamics' started by beastmode13, May 24, 2019.
  1. GreenHokie
    GreenHokie Member
    central Virginia
    OK. You’ve inspired me. I’m going to drill mine this weekend!!
  2. gundarx
    gundarx Member
    Renton, WA
    From the perspective of a Model Y MPP comfort adjustable coilover owner, I'm a bit jealous of your symmetrical adjustment settings (ex. 12/12 front AND rear / 12/10 all-around)
    for comparison, MPP suggested settings for Model Y vs. approx. max number of turns to full-soft are:
    front
    compression (bottom adjustment): 12 / 14
    rebound (top adjustment): 12 / 19-20
    rear
    compression (bottom adjustment): 10 / 13
    rebound (top adjustment): 8 / 20
    represented a different way:
    front 12/12 (compression/rebound turns from full stiff)
    rear 10/8 (compression/rebound turns from full stiff)
    a little bumpy for daily driving with my family, so I'm currently at the following but likely will tinker with it in coming days:
    front 13/16 (compression/rebound turns from full stiff)
    rear 12/12 (compression/rebound turns from full stiff)
  3. turbotony
    turbotony Member
    Alameda, CA
    Had my local shop drill just above the damper housing and they gave me a rubber grommet for it. Works like a dream to not have to remove the frunk housing each time!
  4. SK360
    SK360 Member
    Pittsburgh, PA
    Spent some time dialing in ride height a bit today, I took the center caps off and used a tape measure to hook into the top of the hub and measured to the fender from there. With the Performance wheel design I put it in Tow mode and rolled it back and forth until it lined up to get a uninterrupted vertical measurement. Also took the time to change to 8/10 on all the dampers and took it for a quick spin on some back roads. I giggled a few times. Getting it aligned Tuesday at my buddies shop, didn't get any of the rear arms but need to 0 out toe.
  5. MountainPass
    MountainPass Vendor
    Toronto, Canada
    Awesome, enjoy! I am running 12/10 right now during the winter since I won't be carving any roads anytime soon.
  6. SK360
    SK360 Member
    Pittsburgh, PA
    Coming from a C6 Corvette with Z06 shocks and a C7 Corvette Z51 with magnetic ride set to sport 99% of the time even at 10/8 it doesn’t feel any worse than either of those. I’ll probably go back to 12/10 between events for maximum Wife Acceptance Factor but enjoying this for now.
    I def need to get those holes drilled for the front rebound. Got some grommets coming tomorrow, just gotta see if I can line up the drill right :p. Was able to get to front compression with the wheels turned (my fingertips hate me) and the rears slightly jacked up with wheels still on.
