On my last run, I did some runs that were high speed sweepers, and the 10/12 settings were not enough. Too much float at speed. I have since change to 8/10 and will see how that is this weekend. Not sure if sway bars would help with the high speed float when hitting bumps, but worth a shot?
Try these on for size:On my last run, I did some runs that were high speed sweepers, and the 10/12 settings were not enough. Too much float at speed. I have since change to 8/10 and will see how that is this weekend. Not sure if sway bars would help with the high speed float when hitting bumps, but worth a shot?
That might be a little stiff on the street, I will see how my new settings are. Thanks.Try these on for size:
Low Grip / Technical Track Damper Settings (clicks from full stiff – higher number is softer)
- Front Compression: 9
- Front Rebound: 8
- Rear Compression: 6
- Rear Rebound: 7
Thanks, it is definitely stiffer, but hopefully the best of both worlds.That's where I have mine set 10/8. Seems pretty secure without being stiff.
I plan to auto-x this weekend and will start with the MPP recommended settings for low grip / technical tracks. I wonder if anyone has any preferences otherwise on a m3p with these coilovers?
Thanks. I am coming from a fwd platform and still getting use to rotation. I might consider a more even setup in that case.Depending on the condition of the parking lot you could stay with those settings or go firmer if you can. I have a loose and fast AutoX style so I go firmer in the rear than the front to encourage rotation.
I needed to drive down the 5 fwy today to return some rims to have them machined properly, and was overwhelmed by the smooth ride over perhaps one of the worst freeways in southern California. Washboarding, pot holes, undulations, it was so smooth it made me take notice. I can say without trepidation that the MPP Sport Coilovers at street settings (12/10) are way better than stock and perhaps would even satisfy those with tender bottoms (you know who you are LOL).
So, 10C/8R was very good today on the street. My tires were the only limitation. With new tires, I would feel better going 9/10ths. No mushiness going fast in the high speed sweepers, but the ride for every day is more like a Corvette. That is fine for me, but not for those wanting a Cadillac ride. I am thinking of adding sway bars to help things just a little more.
I am driving around at 12/12 right now and I still get excited driving through terrible city roads on them and asking my friends if they think the car is modified at all!Also at 10C/8R here. Firm yet controlled. Love the MPP Sports!
Was originally at the recommended street settings of 12C/10R. Might try 11C/9R as a compromise...
- Front Rebound: 8
- Rear Rebound: 7
