Super helpful, and really nice pics to boot!I hope this response can provide some insight and value to you guys. I've installed both the adjustable and non adjustables and will say that the non adjustables are amazing if set to their optimal ride height, 365 to 380mm from hub center to fender. If you want to be lower than 365mm then you should go with the adjustables. I personally think 370mm is perfect for them and where I set the car below. It's basically the same drop as Eibach springs out of the box.
Is that 370mm front and rear? It looks like it's slightly closer in the rear as it normally is due to how the fender is cut, or is that an optical illusion?
