Atraf
off road range, driving in deep sand up a mountain, is about 100 miles, not accounting for gliding down all the way to the road.
Enjoy =)
Great video. I showed this to my wife. Her response was to remind me that the other day I said I wouldn’t be putting a load of brush in the back of my MY to take to the dump, like we did in my CX-5 the other day - ‘But this guy is getting his car totally filthy inside and out!’Ture to his brand another video about the setup without actually giving the require information in order to be able to replicate it, and a video montage of wrecking his own car like its a company car.
Unknown offset that makes the wheels protrude, (ET+20mm ? 10mm?)
18" wheels,
No idea about wheel width/J (probably 8.5"?)
Tires are toyo Open Country AT3 (https://www.toyotires.com/product/open-country-at3) - but we don't know the size (probably 29" overall diameter, last video he mentioned it was 30" and rubbing and he was going to down size)
For all we know the guy plans to get/make aftermarket metal bumpers (like the ones you see on Jeep Wranglers) as well as skid plates and thus doesn't care when all of his plastic bits fall off / break.Great video. I showed this to my wife. Her response was to remind me that the other day I said I wouldn’t be putting a load of brush in the back of my MY to take to the dump, like we did in my CX-5 the other day - ‘But this guy is getting his car totally filthy inside and out!’
/QUOTE]
This I feel is much more inline with things most people would consider doing with their vehicles
If a +20 offset works for a rim - does this possibly work ?
18" DIAMETER (18" x 9")
[+20 Offset, 5x114.3 Bolt Pattern, 78.1mm Hub]
Question for the group: I will definitely be lifting the MY I have on order with the MPP 1.75” lift kit. Since mine will be the LR AWD version, does the group know if that gives the ability for a larger tire than being guessed at so far? Because it’s my understanding that the performance version is lower than the long range version. I’m thinking I’ll use an 18” rim and I know nothing about how to size things properly so would really appreciate the help figuring it out! i1 Tesla said the 30” (255/55R19) was rubbing so he was going to try 29.6” tall setup next (245/60R18) - but his is a Performance model that he raised 1.75” so wouldn’t an LR have maybe an inch more meaning what is rubbing for him may not rub on a LR model? Also I would like my tires to stick out a little - his don’t look like they do to me - would I need spacers to accomplish this?
Perfect - thank you both!! @Nakk and @Atraf - Great information about what I need to keep in mind for this daily driver vehicle regarding offsets vs spacers, mileage impact of tires, impact of sizing near/around the knuckle, etc!! I’ll watch the videos provided and take the suggestion on seeing if a tire shop can do a test fitting after adding the lift. It will be a few months but will share results after delivery and once it is all completed.@HeartSong I agree with what @Nakk said fully, I also gave best guess to what would work but nothing is confirmed.
Here is an excellent video about all terrain tires:Its not apples to apples but the concepts are solid.
For the Model Y, the limiting factor is the front upper knuckle:
View attachment 590903 This picture is from a Model 3 but it should basically be the same.
The lift seats between the car and the suspension, way above the front upper knuckle, just like in the Subaru video, it doesn't change the tire limiting size, in theory, whatever you find to be the biggest tire that can fit ... would fit all the same with or without the lift kit.
Having said that, there's another way to go about it, if you get enough offset ... you will essentially be relocating the wheel next (instead of under) the upper knuckle, at that point the only thing you have to worry about is rubbing the inner wheel well.
If you choose to use big offset to dodge the knuckle ... keep in mind that due to changes in wheel location geometry you will be losing about 30% of your range.
Also, all terrain tires are not as efficient as all season or summer tires so you will be further losing even more range. before factoring cold/hot weather .... you can easily expect to only have 150 miles of range (if that), so you might want to stick to getting as close to the knuckle and as close (but not to the point of protruding) to the edges of the car for wheel location.
I am making many assumptions here about your plans and needs, for all I know this could be your weekend adventure car and you might also never be going further than 50 miles from your house, at which point you can easily do as crazy of a build as you want and not worry about range or anything really....
Example: "Safari" Model 3:
View attachment 590904 View attachment 590905 View attachment 590906
Feel free to share any additional thoughts that come to mind in the meantime since as a girl trying to talk to a tire shop about these considerations is going to be awkward for me to say the least Wish me luck!
Thats awesome! I can't wait to hear how it works out for you, thank you for sharing all of the above!Hey all,
I too have been really interested in the MPP lift and upsizing tires. We live in a rural area with lots of crap roads - so I'm not trying to make this thing an overland rig - just a little more clearance for the ruts and snow... I reached out to I1 Tesla multiple times and got no good info... However, I did stumble into a great situation - and wanted to share everything I've learned so far.
It's kind of a long story with lots of boring details that I won't go through unless you ask - but I ended up calling a wheel, tire and suspension shop near Seattle to ask about getting new wheels and tires and it just so happened that they were doing the exact same thing for another Model Y at the time (so random). Originally that other person was just upsizing their tires, using the stock 19" rims... they tried 255/55/19 Continental Terrain Contact tires but they rubbed the suspension knuckle in the front. Using a 1/4" spacer, they were able to eliminate the rub.
The guy at the shop suggested that I look into different offsets since I was going to get new wheels anyway... I figured, if I could get wheels with an offset that moves the wheel out at least 1/4" I should be good. Since I also wanted to go with 18" wheels, I headed over to willtheyfit.com and started looking at spacing. Turns out - with an 8.5" rim and 35mm offset, the outer face of the rim doesn't change position much, but the inner surface moves out quite a bit (22.7mm or 0.89 inches). If you haven't been to willtheyfit.com, it's an awesome resource. I didn't know squat about tires/wheels/offset before exploring the site.
Anyway...
After talking with this wheel shop more - it turns out the other customer wasn't super happy with the 19s plus spacers, so he worked with the shop to find other options. The shop is a Black Rhino dealer, and the shop guy there did a ton of research to find 18" wheels that would fit, and have the right load rating. At the end of the day the other owner ended up going with 18" Black Rhino Barstow wheels (18x8 with 30mm offset) and 245/60/18 Falken Wildpeaks.
I personally don't like the way the Barstows look, and they are pretty heavy, as are the Falkens. So I'm going with Black Rhino Mozambique 18x8.5 with 35mm offset and Yokohama G015s. The Mozambiques only weigh 25lbs (I know they aren't as light as the Martians, but they are also cheaper and look truck-ier - if that's a word) The G015s are also lighter than the Falkens in the same size. (Stock 19" wheels are ~30lbs and the stock tires are ~26lbs -> the Mozambiques are 25lbs and the G015s are 33lbs so the setup is still a little heavier, but not grossly) It would appear as though Black Rhino wheels that are Rotary Forged, should (check for yourself, I make no guarantees) fit the brakes, and they are generally truck wheels, so the load rating is good to go. (Black Rhino is part of TSW wheels, so they are good quality)
My Model Y should be showing up any day now? Hopefully? - this shop is going to do the MPP lift install and the wheels and tires for me all at once - with an alignment in there too.
So I need to give a shout out - If you are in the Seattle area - the shop is called Kirkland Tire Pros, the guy I was dealing with there is Aaron - and the customer service has been second to none. Literally a 36 email chain of back and forth with questions, comments, and pictures... unreal. And to know that he worked so hard with this other guy to get the exact right wheel/tire combo... I can't believe I stumbled into it.
Anyway - when I get it all installed I'll be sure to come back and post pics and let you know how it goes firsthand.
Thanks for the update - it’s encouraging to see the efficiency is still goodThought I'd update my efficiency now that I have 1000 miles on the lift kit. Since new: 6500 miles, average 295 wh/mi. 1000 miles since lift kit install. 1000 mile average 295 wh/mi.
Really helpful info - I was leaning towards a Fuel wheel if it would fit but since you provided great details on Black Rhino, I’ll be sure to take a look at them as well, thanks!Hey all,
Anyway...
Hey all,
Anyway...
I’m located in Seattle and was looking to get the same thing done. How much was the install cost?Hey All,
Just thought I'd post an update.... finally got the MPP lift done. Also replaced the stock 19s with 18" Black Rhinos Mozambiques. We just got our first snowfall last week - and temps are dropping - so rather than a set of ATs I got Conti VikingContact 7s for the winter. I'll replace them with some mile AT tires this spring.
I live in the Methow Valley - North Central Washington - and as you can see I've already got some valley dirt on the car there. I"m not really shooting to make this an off-road beast or anything silly like that. I just need a little more sidewall and a little more clearance to handle the road I live on... we also do lots of hiking and mountain biking.
It drives similarly to the way it drove pre-lift and wheels. You can feel a touch more roll in the twistys, probably from the increased height and sidewall. But overall not too terribly different. It "feels" bigger - and is noticeably taller - even though the total lift between MPP and larger tires is really only 2.5". I will update more when I have better efficiency numbers.
Huge shout out to Aaron and the folks at Tire Pros Kirkland. They were awesome!
If any of you have questions, I"m happy to answer.
(Oh, and I"m selling my 19" Geminis and tires if anyone in WA is interested)
That looks awesome! What size tires and wheels did you end up with?Hey All,
@PNWLeccy Reach out to Kirkland Tire Pros, ask for Aaron... Very reasonable pricing. I'm hesitant to say because I was the first MPP kit they'd done and I don't know if they'll change their pricing after doing mine... . But it cost me less than I thought it would...I’m located in Seattle and was looking to get the same thing done. How much was the install cost?
@MountainPass They are 245/60/18s on Black Rhino 18x8.5 with a 35mm offset. The tires right now are Conti Vikingcontact 7s for the winter.That looks awesome! What size tires and wheels did you end up with?
