I just installed the Mountain Pass Performance 1.75" lift kit on my Model Y PUP. I'm going to add install instructions here as well as test numbers and driving impressions. If you look closely at the "AFTER" picture, you'll see that there is a shadow on top of the tires that makes the gap look bigger than it is. I'll try and get some better pictures later.
For starters, I did a test run for range. Bear in mind I still need to have the car aligned. Also, conditions were not identical compared to my before run. I ran a before run under pretty strict conditions. It's a 10.8 mile loop, so light wind should even out. It's up the freeway a few miles, take an exit and come back. 65 mph, no traffic, 65 degrees. Headlights and HVAC off. I get to speed and re-hack the trip odometer at a specific spot. Anyways, the original before test resulted in 271 Wh/mi. The test I just ran there was some traffic and I got slowed to 60 mph a few times. Temp was 90 degrees, so I had the AC on. On this test post-lift I got 267 Wh/mi. I'll run another test after the car is aligned early in the morning so I can duplicate the original test conditions.
BEFORE:
AFTER:
BEFORE:
AFTER:
