@MountainPass For the Big Brake Kit, whats the advantage other than the better cooling custom rotor since its the same stock caliper?
For example, imagine the rotor was a larger, stock type rotor (like rear)...... Would this still be better than stock in that since the same caliper is "out" more, it has more of a mechanical advantage/leverage against the wheel spinning?
-Is it that the stock caliper is more capable than the stock rotor allows due to its smaller size?
-Or that the caliper doesn't need to work as hard being out more hence it has more room/leverage to brake harder?
-No larger/more piston caliper needed with more surface area to take full advantage of larger rotor?
Reason I ask...because if so, would you ever consider offering an "upgraded street big brake kit" (lower tier kit), mainly street use, where its the caliper relocation bracket and a stock type rotor. Or maybe even just the caliper bracket, and we can buy stock rear rotors? That would be cool! I would think that would sell well....just a thought.
