Hi Guys,
I thought I would give a review of the following kits and my impressions on the street and track. I bought both kits and compared them in both street and track environments. I want to thank Jesse and Sasha at MPP for the help on the transition from Ohlins to MPP as they guided me through every step of the way with tons of technical explanations and detail.
Ohlins DFV:
-This kit uses 4 monotube dampers with rebound adjustment only
-Spring rates are 110N/mm front and 120 N/mm rear
-The kit offers ride height adjustment via preload and adjustable length shock bodies
-The quality of the kit is excellent and instructions are straightforward for install
MPP Sport Coilovers with SuperSport Springs (using lightweight rear spring arms)
-This kit uses 4 twin tube dampers with low speed rebound and compression adjustment
-Spring rates are confidential but they are stiffer than ohlins (especially in the rear)
-This kit offers ride height adjustment via preload
-The quality of the kit is excellent and instructions are straight forward for install
Ohlins:
Street ride:
-I found the kit very comfortable on the street, I set the rebound adjustment to 10 out of 20 and found that to be the best compromise between ride quality and spirited driving
-The kit uses DFV technology which creates a very ‘plush’ compression feel on the street
-Shocks soak up imperfections nicely and you can tell that there is significant volume in the dampers to let the DFV work properly.
-Unfortunately, the default compression setting was a bit too soft; this resulted in an imbalance when adjusting the rebound setting higher as the low-speed compression curve did not track the low speed rebound curve well enough. I found this prevalent on the rear shocks as motions where not kept in check and the car bobbed a bit too much and didn’t feel settled. The front wasn’t as bad but had the same issue. Therefore, I didn’t move the setting at all on the street, 10 really felt like the max I could run.
Track:
-I ran the ohlins at an autox, and got a very quick time but I would of liked more feedback and road feel. I found the rear squatted too much out of turns (needed more spring). As said previously, I found the car had too many vertical motions when I dialed up the rebound very high (4/20) and I could never find the setting that made the car settled and composed enough to inspire confidence.
MPP:
Street ride:
-This is the second most aggressive kit that MPP sells, which you think would be ridiculously stiff on the street and a compromise to live with, but I was amazed at how that was not the case at all.
-The kit was amazingly great on the street even at a very stiff setting (4fr rebound/3rr rebound with 2 compression fr/rr) and very compliant and motions kept in check.
-The adjustments were a piece of cake and take about 5min for all 4 corners
-The increase in spring rates matched the car loading very well. The rear now had enough spring to keep it loaded correctly and made power exiting turns a breeze with no squat.
-Incredibly neutral balance, especially for such a heavy car
Track:
-A completely different car, with the stiffer spring rates and proper shock adjustments the car was always compliant, stable and settled on all maneuvers.
-Transitions were incredibly stable with high-speed sweepers.
-Corner entry superb and power exit fantastic
-Absolutely excellent road feel, allowed me to position the car perfectly
-Confidence inspiring, allowing you to keep pushing the car harder not being worried that the car would get unsettled.
Conclusion:
-Comparing MPP to Ohlins felt like comparing a one size fits all off the shelf application to a custom engineered solution
-My initial reason to go to Ohlins was the DFV and ease of adjustment but unfortunately that came up short in the end: only having rebound adjustable was inadequate and the DFV made the road feel a bit too numb.
-I felt in the the end that the Ohlins kit needed re-valving and better spring choices for serious track duty.
-The engineers at MPP created I think a superior shock and spring solution. I was skeptical at first since I thought they would be like off the shelf KW V3s, but the valving on these shocks is fantastic.
-Spring rates chosen allow for a neutral car balance
-Every adjustment on the shocks is noticeable and precise allowing you to dial up the stiffness for spirited driving and back to normal for the street
-The MPP solution is definitely the better track solution with surprisingly good road manners.
Cheers to the MPP team and looking forward to many fun sessions at the track!
Ohlins DFV:
Ohlins:
Street ride:
Track:
MPP:
Street ride:
Track:
Conclusion:
