MS P85D wheel spacers?
There's a couple of people. Problem is you need pretty significant ones I believe 15mm-20mm and then you need. And then you need to ensure they clear the oem studs otherwise the wheels won't mount up.
Seriously though just google it. Tesla model S wheel spacers. There's a thread here from ay least a year or so ago.
  • Disagree
Reactions: davidc18 and M4guy
Photos with staggered OEM 21s 25 front/ 20 rear
contact Lenny at Motorsport-tech.com
Reactions: JPUConn
I’m thinking about fitting wheel spacers on my P85D (staggered 21” turbines) as I hate the way the wheels sit in the arches.
Anyone else running them on here? What sizes?
The offset for the turbines and arachnids is the same: 40mm. I have the staggered arachnids with Michelin pilot sport. The spacers needed to make the outer edge of the rims flush with the top of the fenders is 22mm front and 18 mm rear. That’s what I have on my car.
Reactions: FlatSix911
Very nice, I've loved seeing your mods, artsci. I'm picking up my P85D on Thursday and my head is swimming with the possibilities. Did you need an alignment after adding the spacers?
Also, did you also use lowering links or brackets? If so, does that change the spacer size to avoid touching the fender?
Thanks in advance!
Thanks in advance!
Thanks @Firecat. Yes, I have lowering links. You might want to see this thread for the details. If you install the lowering links you'll want to have the car aligned at the lowest setting (unless your settings never lower the car at speed). Otherwise the spacers make no alignment difference.
When I back up the car the front tires rub the fender well a bit. But it's not serious, so I've learned to live with it. The rear is not a problem.
Ok guys so all fitted today, I ended up going with 20mm all round (15mm don’t work as the stock studs are too long. 18mm would work)
I lowered the car using Airmatic adjustable links and they were great quality and easy to install.
I’ll get better pics but here’s a few for now in its standard setting.
For reference it’s a P85D on staggered 21” turbines
looks great!
