MS wheels will not fit M3. Different bolt pattern
Discussion in 'Canada' started by 03DSG, Sep 8, 2017.
Tags:
  1. 03DSG
    03DSG Member
    Cobourg, Ontario
    I posted over on TMC. Copied her for us Canadians.
    It turns out that Tesla has most likely changed the bolt pattern for the M3. The MS 19 inch wheels use a 5 x 120 bolt pattern. We now have an indication that the M3 will use a 5 x 114.3 bolt pattern.
    TSportline has a M3 wheel guide:
    The Tesla Model 3 Wheel and Tire Guide
    Bolt Pattern
    TSportline and Tesla sell MS wheels with a 5 x 120. This makes sense to me. As the M3 is much lighter than the MS the disc brakes and corresponding hubs don't need to be as large. Using a smaller bolt pattern may keep the design in scale. Both 5 x 120 and 5 x 114.3 are very common in the industry. I'm contacting TSportline to verify.
    Just spoke to TSportline and they said the information they have from Tesla is the M3 bolt pattern is indeed 5 x 114.3. They will be confirming this later this month an a customer car. If true this locks out using ANY MS wheels on M3.
  2. McRat
    McRat Active Member
    Norco, CA
    Perhaps due to the large difference in weight between the cars, they deliberately changed the pattern so M3 wheels would never be used on a MS/X
  3. 03DSG
    03DSG Member
    Cobourg, Ontario
    Very well could be. They also might of done it to prevent M3 buyers buying used MS wheel instead of upgrading to the M3 19".
    • Disagree x 1
  4. e46jb
    e46jb Member
    Calgary
    Is this proven to be true, or speculation. I have seen both bolt patterns listed for the Model 3.
    TSportline is showing 5x114.3
    Other sources are showing 5x120
