We are now working on a solution of multi-camera solution for Model S / X of which provide more comprehensive blind spot monitoring to the user. This multi-camera solution is to display the camera images on the Tesla screen by the respective display mode can be switched by the control on the steering wheel.
The multi-camera solution can adopt up to 3 pieces 720p cameras (frontview, left-view, right-view), altogether with the factory rear-camera, as a result of maximum 4 cameras for the blind-spot monitoring, with the output LVDS signal directly to the AP Engine or the HDMI Interface Box. Which means, if you don't have the HDMI Interface Box, you can still use this multi-camera box in order to perform up to 4 camera views (front/left/right/rear) for upgrading the blind-spot monitoring for daily use.
We are working on the PCB layout of this project, would probably to have the 1st working prototype by end/June.
Each of the display view is implemented by triggering the CAN signal. For rearview is triggered by "R" transmission, leftview by left turn indicator, right0-view by right turn indicator, and front-view by D/N transmission.
