1,293
518
After SpaceX completed a mission over the weekend to launch cargo and supplies to the International Space Station utilizing previously used equipment – a historic first – Elon Musk took to Twitter to say it’s an accomplishment that already feels normal. It's starting to feel kinda normal to reuse rockets. Good. That's how it is...
[WPURI="https://teslamotorsclub.com/blog/2017/06/05/musk-says-reused-rockets-feel-kinda-normal/"]READ ARTICLE[/WPURI]
Reactions: Grendal
ecarfan
19,342
14,008
West Vancouver, British Columbia
Heh. Yes, basically that seems about right. Note that the Dragon capsule that was just launched and is now docked at the ISS is the same "pressure vessel" that was used once before for a mission to the ISS. SpaceX recovered the dragon, stripped it down to the fundamental structure, the pressure vessel, and rebuilt it. A lot more work than re-flying an F9 1st stage, but still re-use!
Reactions: Grendal
Grendal
SpaceX Moderator
Jan 31, 2012
5,965
7,484
Santa Fe, New Mexico
At this point SpaceX is recovering every booster they try to recover. They are still losing a few but only because they are doing it intentionally and clearing their original Falcon Heavy launch list.
Grendal
SpaceX Moderator
Jan 31, 2012
5,965
7,484
So how many successful stage recoveries in a row are we at now? 5?
They're really at 7. The last time a booster recovery was attempted and failed was EutelSat-ABS on June 15th, 2016. Basically a week less than a year ago. It was a pretty heavy GTO attempt and SpaceX was playing with the landing algorithm to get a "hot" landing to be less hot. It was the last three engine hoverslam landing attempt. Since that time SpaceX seems to have perfected the single engine landing burn which protects against a lot of the heat damage. I expect the next landing issue to arise will be the first block 5 launch or the first Falcon Heavy triple landing attempt (whichever comes first). The rocket design will have changed and so that has to increase the chance of an issue arising by some amount.
Elon Musk is on a roll. SpaceX is killing it. The Model 3 will arrive on time, which is a first. We just need the 3 to be as great as it can be and the Falcon Heavy launch to be nominal. If those two things happen then Elon is on fire!
