I have the two profiles for my MX linked to the FOBs. However the profiles don't change depending on which fob is used to enter car. Am I missing a setting or something?
Thanks to everyone. It sounds like their might be an issue with my car or the fobs then. I'm pretty sure that it used to work.
I have to take the car in for some other minor issues so I'll have them look at that as well.
I'll try and remember to post what they say.
I did check that and I think I have it set correctly. I thought at first that maybe I had reversed the fobs but that was not the case.are you sure you have fobs assigned to profiles?
Good to hear, cannot wait for 17.24.28FWIW this is fixed now in 17.24.28. Profiles work perfectly with PUP automatically opening the door and setting the correct profile.
My model s says it has linked my fobs to our two profiles, but, often the car doesn't switch when the "other" fob opens the door. is there a secret to this or is it a bug?
This is a known bug. My brand new MX 100D was in the shop for about 4 days while they tried to figure out why it's not working as advertised. The end result was a note from engineering promising a firmware fix. This was over a month ago so I'm hopeful it'll be soon.
This is the solution. We had the same issue on our X. I basically went through and duplicated all of our profiles, paired the appropriate ones and then deleted the old ones. Works fine now.are you sure you have fobs assigned to profiles? You can check under driver profiles... pick driver in settings and there is info "linked to fob1" or "link to fob1" (or similar).... you can reassign fob to different driver profile by clicking on another profile and then you can assign current fob there... it removes from the first assign profile thoughcheck settings to make sure you have both fobs assigned to some profiles... do one by one as car gets confused when sees both fobs at the same time
Can you just delete all the profiles and start over.This is the solution. We had the same issue on our X. I basically went through and duplicated all of our profiles, paired the appropriate ones and then deleted the old ones. Works fine now.
I haven't seen this working for me. Did you have to do anything post-update, like re-linking the fobs? I have a firmware greater than 17.24.28 and PUP...
You can go that route, as well. You just lose your seat, mirror, etc. settings.Can you just delete all the profiles and start over.
