My 11.2kW Tesla Solar Project - Portland, OR
pdx_m3s
1,230
1,054
Portland, OR
Now that you have the "final PTO" email, you should be able to call tesla energy support and ask them to sync everything up. Probably faster than waiting for them to "just do it".
Tesla can confirm that my Gateway is online, but it is not establishing a connection with the inverter. We went through all of the troubleshooting steps with no luck. They are going to have to send someone out.
Tesla has so far to go with their energy business. They need to bring more to the table than just being the cheapest option in town.
BrettS
2,108
2,511
Orlando, FL
You haven’t connected your inverter to Ethernet, have you? If the inverter is set to auto then Ethernet will take priority and it won’t connect to the gateway.
Reactions: willow_hiller
cantbechanged
89
38
Maryland
@pdx_m3s did they have you log onto the gateway’s network and troubleshoot? Also, did you try resetting it with a pencil?
I had the same issue and resetting the gateway fixed it. For some reason the WiFi got disabled with our smart meter swap.
pdx_m3s
1,230
1,054
Portland, OR
Well a service appointment is scheduled for 11/3 to fix the issue with the gateway not pairing with the inverter.
Also, still no invoice from Tesla.
pdx_m3s
1,230
1,054
Portland, OR
Well some data finally started showing up in my app, but it doesn't seem right. The "from grid" chart (grey) is basically a mirror of the solar generation chart (yellow).
And the "Home Usage" chart is basically just both charts stacked together. It appears that the grey grid chart is inverted, in that it's showing my solar over-production as home usage.
Hugh-SG
80
84
Vancovuer, BC
I had that also when I first got my Powerwall-2 hooked up. It took a call to Energy Support to get it set straight.
Congrats on Net Metering system.
Cheers! Hugh-SG
pdx_m3s
1,230
1,054
Portland, OR
Cheers! Hugh-SG
Thanks! I've called Tesla Support about the issue and they are working on it. I sent them screenshots showing the issue.
pdx_m3s
1,230
1,054
Portland, OR
I received a call from Tesla's new construction team today, asking to elaborate on the mediocre survey/review I gave them. I really appreciated that they took the time to actually hear out a customer. They were very open and honest about their short-comings and were open to hearing about how they can improve.
Also, it appears that they have fixed my monitoring issue. It now appropriately shows over-production going to the grid, rather than showing as energy usage.
I'm curious, how sensitive is everyone's home energy usage chart? Mine usually doesn't show anything unless there is a large load on the system, and it seems very intermittent. For example, mine showed zero usage from midnight through 8am, even though I know our heat pump was cycling on and off routinely to heat the house.
k-mal_808
70
49
Makakilo, Hawaii
My chart appears to be pretty sensitive. I can turn on/off various small appliances and/or ceiling fans and notice the difference in power flow. That's great that they reached out to you after the review. I got the email for the review but am waiting till PTO to fill it out. It'll be a mixed review for sure. Some areas were great, some pretty bad.
wjgjr
974
731
Silver Spring, MD
This is my experience as well - sensitive to small changes, and I can see the fairly constant overnight base load (of roughly 0.5 kWh) in the app and in the underlying data.
After our install, we did get a call from Tesla as well - I don't know if they are doing it for all customers or just some. My sense is they did care about the feedback and at least intended to try and address the issues (my big feedback at the time was lack of dedicated project managers, and my impression was I was not alone.) The challenge for Tesla seems to be they are expanding so quickly that they seem to have trouble making some of these changes effective.
BrettS
2,108
2,511
Orlando, FL
I think this is one of the differences between a solar only install like @pdx_m3s and a powerwall install like @k-mal_808, @wjgjr, and myself. With a powerwall install the tesla app gets it’s data from the TEG and it updates almost instantly.
With a solar only install the data comes from the inverter and the powerblaster and I believe the app only updates once every 15 minutes. Since I don’t have a solar only install I’m not totally sure about this, so it could update a bit more frequently, but it definitely doesn’t behave the same way as it does with a powerwall install.
I would kind of think that when it does it’s 15 minute update that it would update with an average of the power usage over the last 15 minutes, but maybe it only updates with an instantaneous reading at the time of the update?
wjgjr
974
731
Silver Spring, MD
That is a good question that somebody with solar-only would need to test. When downloading the app data (including PW,) the 5-minute data is labeled in "kW" so I am assuming it is instantaneous data, where the daily numbers are labeled "kWh".
pdx_m3s
1,230
1,054
Portland, OR
Well, after having the system up and running for 9 days following PTO, Tesla finally sent me an invoice.... for half the system cost. The email starts off with "Since your installation has begun..." and the goes on to say, "we cannot interconnect your system until we receive your final payment." Haha.
I think they're a little backed up.
For those wondering, I was able to pay via PayPal and credit card.
pdx_m3s
1,230
1,054
Portland, OR
Here's a breakdown of the total system cost:
