My app will not connect to car that's in service?!
Discussion in 'Model S' started by number12, Nov 30, 2016.
Tags:
  1. number12
    number12 Supporting Member
    Tesla
    does this mean my 7.1 car is currently being defiled with 8.0?
    If not, why would this be the case?
    Seems shady either way. I never gave them permission to update and even asked them not to.
    And no items needed firmware updates (I don't think so).. I sent an email asking to be contacted if update was needed.
    Any advice would be appreciated.
  2. gde_eu
    gde_eu Member
    Europa
    I think they now switch off remote access when in service...
  3. Patrick W
    Patrick W Active Member
    SLC, UT
    Correct. Keeps owners from doing silly things light flashing lights or honking the horn while the car is being serviced.
  4. number12
    Tesla
    Makes sense. Still bit fishy. I forgot to tape a note on the screen to not update, but whatever is done is done I guess
  5. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    They also unplug dashcams...
  6. FloridaGary
    FloridaGary Member
    Orlando, FL.
    Correct. Standard operating procedure and safety for the technicians.
  7. green1
    green1 Active Member
    Calgary, Alberta, Canada
    Which is why I have my car set up to automatically re-enable remote access every minute. It means that if someone like a thief (really Tesla, this doesn't require a PIN????), or service tech, turns it off, the car will automatically turn it back on so I can see what's happening.
  8. Kurt'sX
    Kurt'sX Member
    Victor, Washington
    I wasnt sure, but you guys seem to have confirmed it. My X has been in the shop for 3 weeks and all contact with the car has been shut off, including my Blackvue dash cam. They arent letting me check out any of their secrets! LOL
  9. CuriousG
    CuriousG Active Member
    Elk Grove, CA
    We can't all have the luxury of having root access. PIN? Nitpicking aren't we? Why not criticize Microsoft for not requiring password to turn off Remote Desktop services then?
  10. green1
    I might nitpick Microsoft, but I don't use their products. That said, you DO need a password to turn off Remote Desktop services, you can't do it without admin access, which you shouldn't be using on your normal account (just because most people do, doesn't mean it's a good idea)
  11. CuriousG
    Elk Grove, CA
    I think of it this way, you are admin user when you have the keyfob. If that wasn't the case, you shouldn't be able to set the pin for valet mode either. So then once you are signed in as a local admin you don't need password confirmation to make the Remote Desktop change.
  12. gutowskia
    gutowskia Member
    Orangeburg, NY
    I believe the access is turned off server side. I dropped off my winter wheels for service and lost app access to my car despite the fact that the car was with me all along.
  13. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    8.0 comes with just enough benefits you won't feel too bad about the extra AP nagging.
    Other than the nags it's pretty much all good, especially now the USB issues have been mostly resolved.
  14. green1
    What possible benefit could 8.0 give that would be worth giving up AP????????????
