My biggest improvement with road noise
destructure00
1,476
1,629
Scottsdale, AZ
will this help?
the gap near the b-pillar is clearly very tight, it won't even fit a piece of folded paper, apparently the A pillar gap can easily slide it down
There's two possibilities there...it could be that the window track needs to be adjusted to make the top edge of the window move inwards and press harder against the seal, or it could be that the window position needs to be moved up inside the clamps so that it jams harder against the seal when it goes up. Two different adjustments.
Here's another video regarding window position adjustment.
Reactions: JBT66 and asian_xl
asian_xl
275
191
Hong Kong
Thanks a lot that's a good project to begin.
for adjusting the position bolts, let's say after I loosen the front bolt, do I grab the top of the winodw and pull it upward? unlike the track adjustment we can use an allen wrench to push it out by rotation. I believe it is just a tiny gap, don't want put up too much and hit the top trim.
destructure00
1,476
1,629
Scottsdale, AZ
Yes, just grab the window and move it where you want it to go..
TLLMRRJ
2,011
1,996
Houston
I'm curious as to how you liked the Trackace alignment tool. Comments on their YouTube video didn't seem all that positive.
Your experience seemed very good overall?
Yes, that's why I am recommending it. But honestly, there are people that can't even follow directions for using a California Duster correctly and they end up scratching their paint, so I can say without a doubt that the negative reviews are the people that just can't follow instructions.
It takes a couple of times to get comfortable with setting up the Trackace to take the measurement, but after that, it's quick and a lot easier than measuring with strings and rulers, and you get an extremely accurate result.
Reactions: Dave EV
TLLMRRJ
2,011
1,996
Houston
I"m not sure if this is a Model 3 area in the forum, I kinda got here by accident. Nonetheless, where do you get the specs for the front and rear alignment? I would need specs for a Model S, but suspect the source would be the same.
You can buy bootlegged copies of the shop manuals online. Just do a search.
TLLMRRJ
2,011
1,996
Houston
I have “lived” with a very slight steering wheel off-center (2° to right) on my Model 3 SR+ since I picked up the car on June 8, 2019. When I noticed the problem and scheduled the mobile ranger he said that it was not just a simple matter of removing the wheel from the spline and reattaching in the center position, but that an alignment would also be necessary. Bottom line...I never have had it done. I began to considered the off-center steering wheel just a beauty mark. When the tires were rotated at 10,000 miles no unusual wear was observed. I do “launch” when appropriate but otherwise no hard cornering. Am I lucky?
You can have your steering wheel off center by 45 degrees and the car can still track straight and you can still have zero extra tire wear. The steering wheel centering is a different matter than the alignment. In my case, I had the steering wheel center off, and in my quest to get that fixed, I found out on my own that the alignment shops (Tesla and independent in this case) had left me with way too much toe. That was causing premature wear and extra road noise.
TLLMRRJ
2,011
1,996
Houston
The track guys should weigh in on this subject. I am guessing that your Jaguar had Perelli P zeros. I have put a hundred thousand miles on them in two XJRs and a XKR. They have great grip and low noise. I am betting that these on a Tesla would out handle in every way the standard Tesla tires. Thirty six psi would be just fine. They would probable reduce range 10% but they would be much quieter is my guess. I don't care about range as I won't be using the Tesla for long distance travel. You can't beat a XJR as a road car. I just don't like range anxiety.
I had Continentals from the factory. Then I switched to Michelins, and finally I fell in love with the Firestone Firehawk Indy 500's. Never had Pirellis.
That Jag XF was so nice, I bought 2 of them. They are such perfectly tuned cars for daily driving while still being sporty. But alas my XF's were getting old, and they stopped making the NA 5.0L V8, so I decided to go another route.
XLR82XS
D M C
Jul 26, 2019
3,148
1,802
SWFL | Vegas
I don't know where you procured your P-Zeros but I hate Pirellis due to the fact they ARE noisy and hard after ~1-2 years. Yes, you can beat a XJR as a long-distance road car.
XLR82XS
D M C
Jul 26, 2019
3,148
1,802
SWFL | Vegas
Possibly but I have had no excessive wear at ~11K miles and run Tesla recommended cold pressures of 41-42 PSI. 1 tire rotation at 9K. I had an off-center steering wheel on the 2020 at delivery and service center aligned the car before it's first 1K miles. I try to avoid hard cornering as well and think that has played well for tire wear.
SammichLover
Banned
Dec 8, 2018
2,618
1,543
Yup
Being in Houston, I can highly recommend swapping out the stock MXM 18" with the same sized Michelin PS4S. I found the difference to be massive. Not really anything on the noise, but the stopping distance, stability in corners is huge on dry pavement/concrete. In water the PS4S are like magic. Driving through a Gulf Coast downpour with standing water on I45 because it can't run off fast enough, your windshield wipers on high trying to keep up? Feels like a clear, summer day. :) The only warning is that the grip will feel so good you're at risk of forgetting you can still get bit of hydroplaning under heavy braking, so make sure to remind yourself not to overdrive the somewhat reduced braking distance.
Bonus is they'll wear a lot slower (in spite of the lower wear rating). I haven't tried the Tesla OEM 18" version, the PS4. I can't say if the extra acoustic foam is worth the substantial extra money. IIRC it was an extra $100 for the set when I was pricing them. I have heard there is very little difference in grip, the compound formulation is only slightly firmer in the PS4, so they're probably an acceptable choice, too.
On tire pressure; I've found that standard size 18" tires on the 3 tend to start getting a dead feel when dropping below 38-39PSI cold. The turn-in delay might not bother you much, depends on how you drive I guess, but it is a sign that you're putting extra flexing wear on your sidewalls. I wouldn't drive on 36PSI, I target 39-40PSI cold. It does save on center tread wear over using the Tesla stock 45PSI or 42PSI.
asian_xl
275
191
Hong Kong
Hey, I ripped the door panel apart and found the window actually sticking out like this already, it is even possible to go up even further?
Skivvy
30
13
Clermont Florida
So I've got a Model Y Performance i'm trying to get someone to align after a curb jumped in the middle of the road. I replaced the rims and wheels with some from Tsportline. I'm happy with them but of course need to get it aligned. Nobody will touch it, saying bs about sensors and steering homing blah blah blah.
I'll order one of those alignment tools if you recommend it. Any tricks to doing it or tips you could recommend?
TLLMRRJ
2,011
1,996
Houston
It's really all about just doing it right by following the instructions. If you decide to skip or not do any step correctly, you won't get a good reading. It's one of those tools that you can't decide that you feel like doing it your way. It's their way or no way. So just watch the video, take your time, double check you are following the instructions, and it all goes well.
I do recommend getting 2 pairs of plastic sheets and putting heavy grease between them so your wheels can slide easily during adjustments. You might be able to work on the tie rods on the Y without jacking up the car. If so, just drive onto the plastic sheets. Otherwise you can put them under the tires when you are lowering the car.
Crazy that your alignment shops won't touch a Tesla. It really is pure ignorance on their part, but you are better off doing it yourself considering what a crappy job they do these days. I had to redo my Lambo today after paying a fortune for a professional alignment. As a bonus they over-torque the locking nuts on the tie rods to the point that I had to use a large flare nut wrench to keep from stripping the nut from the amount of force it took to get them off. Bozos. Fortunately, I have all these weird tools in my toolbox.
Skivvy
30
13
Clermont Florida
Luckily i found a guy that does alignments. Even better is that he comes to your location and does it. He's got a good portfolio of previous work and didn't even stutter when i told him it was a Tesla. He said as long as i have the right specs, no problem.
This is why i'm going to start finding more small local companies where the owner is a tech or actually works on cars. They'll actually try to earn your business and work with you instead of saying "not in my computer can't do it"
