I went to the hardware store and bought the following...
1) A 7/16 inch locknut to be glued on top of the stripped bolt and used as a dummy hexagonal bolt which I will attach with....
2) JB weld 2 part epoxy mix for metal which has 3960 psi holding strength... and 550 degree strength I plan to masking tape around the stripped bolt so if any loctite makes it onto the underlying surface, it won't defeat the purpose of turning the bolt
3) Sandpaper to rub the metal oxide coating off the stripped torx bolt prior to putting the glue
4) A Sparkplug extension for a wrench that fits a 7/16 inch bolt/locknut... I will grip the spark plug extension with a regular big ass wrench
I plan to fill the hole of the locknut which will also fill up the stripped bolt which is now in a fugly shape of a up torx plus 45 bit well as create more surface area for the bolt that will bond the epoxy stuff...
Now, in theory, this might work...
in reality, it's probably not going to work because psi holding strength may not equate to lbs. feet of torque required to break red loctite. If it works, I'll be amazed. If it doesn't work, I will just have to take it to a welder and have him do the same thing with an actual welded nut.... the reason for doing this is way is to see if I can do it without having to coordinate with a welder... and it is unlikely to damage the car, also, I have the replacement bolts in hand, which is why I don't want to cut the bolts out since I need the barrell nuts need to stay in place for reassembly. My only other question is whether I should try and heat this assembly up a little bit... since red loctite loses most of its strength at 450 F.... and the epoxy says it stays cured up to 550 F I'm wondering if I heat it up a little bit... let's say to 250 degrees, would it be enough to weaken the red loctite without weakening the JB weld? Or is it more likely to weaken both in equal measure? Anyone here have any mad chemistry knowledge that can help me breaking bad this bolt off? If it doesn't work... maybe someone can tell me how to make meth?
