I have a 10 week old MY, and the black trim is starting to show rainbows and almost a rust in some places. Assuming this is from chemicals in a touchless car wash. Thoughts on restoring it, then protecting it?
I got this today also from a touchless car wash... noticing you're in MN, maybe we got it at the same car wash LOL. Holiday in Elk River. Glad to know it's only going to get worse.
It’s gotta be the tri color wash they do. I was able to remove it all with a microfiber cloth and then put ceramic clothing on it.
You could use meguiars hyper dressing, doesn’t exactly fix it but the trim will be black. I use that stuff on my tires and can be used for trim. Meguiar's D170 Hyper Dressing, 32 oz. RTU
Thank you for the suggestions! I will try a service appointment and also buy the hyper dressing and back to black.
This same thing happened to my Y as well. I sprayed a degreaser on a microfiber cloth and it wiped right off. Going to a different car wash today to see if this happens again.
I wanted to send an update. So far I have tried the Orange degreaser from chemical guys and meguiars hyper dressing. Back to Black hasn't arrived yet. The orange degreaser helped, but the pattern was clearly still there. Maybe I needed to use more and rub harder. The Mequiars hyper dressing made it look much better, almost as good as before. I can still sort of see a little of the soap pattern, but it is very hard to see. I don't know how long it will last, but I will keep you updated. Below image is after and before using the orange degreaser. Below image is After and Before the Mequiars.
Is this something we just have to live with now? I've never heard of any other car's plastic getting affected like this from a car wash before.
It's actually not plastic, it's black anodized aluminum. I used WD40 on a microfiber towel and it turned out pretty good. I'm going to wait a couple of days then apply 303 Aerospace Protectant. But I agree with everyone else that should not be happening to such an expensive car!
I had mobile service out today for a different issue and they said that the door trims being discolored like this are not a warranty item because it's from the high pH values in the chemicals in the car wash.
