GtiMart
Seat heaters: I was just giving a counter-example, don't take it too seriously. I didn't check OP's message closely enough that's all. No worries.
There's a limit to the energy that heating will use, once the cabin is already warm. Instead of consuming 6-7kW initially it will probably go down to 2-3kW constant. Over an hour that's 2-3kWh. Driving 120kph instead of 100kph probably consumes ~50wh more per km, which would amount to 6kWh more over that same hour. Rough numbers to give an idea. I'm not saying heating is insignificant, I'm saying that if you need to conserve energy you can start by slowing down (on the highway). If you need to save more you can certainly reduce heat.
