Thx for the suggestions! How do you explain the differences in the photos I attached though?
I really struggle to see what it is being depicted in the two photos. They are too close up for me to get my bearings.
This is what I know about the front seat bottoms.
From the top down (not looking from the bottom up):
The driver's side doesn't have a rather large black flat plastic part between the seat cushion and the metal springs, beneath the foam which is beneath the faux leather.
The passenger side does have a rather large black flat plastic part between the seat cushion and the metal springs, beneath the foam which is beneath the faux leather and above the springs.
The rather large black plastic part I'm speaking of is pictured in my hand in the attached two photo(s). Once again, that plastic part is not on the driver's side at all. The foam sits directly upon the metal springs but only on the driver's side.
On the Passenger side, that rather large black plastic part is designed to be a sensor, but has an unintended affect of stiffening the springs and raising the foam of the cushion up slightly. A person sensitive to this seat design will feel the difference affected by that black plastic part pictured in my hand, which only on the passenger side.
Please also note:
There are additional plastic pieces underneath the springs on both sides, I think most if not all of them are white. Their attachment plastic "pegs" could be black, I'd have to look. They are there only to support various electrical connectors underneath the seat and serve no purpose regarding seat support and will not be felt sitting in either seat.
The foam of the seat are different ONLY in one single way. But they must be marked as being different. The foam is the same.
The driver's side has an extremely thin and rather small inconsequential film sensor that cannot be felt and doesn't raise the driver's position whatsoever. It is glued to the top of the foam, under the faux leather topper. The faux leather are also different but have no affect upon rider feel. There is an additional very thin wire in parallel with the heater wire, both are sewn into the faux leather topper, on the passenger side only.
I hope this is helpful information.
Sincerely,
George Borrelli
