You’re stupid and you’re wrong. I guarantee I would drive laps around you in any weather conditions. Does making sweeping generalizations about 50% of the population make you feel better about your own insecurities?
How does this relate to another driver in a car they are accustomed to hitting the owner in their new car lol?
Because if someone is breaking awkwardly (as they get used to the way the brakes respond in a new Tesla) they are probably somewhat more likely to get rear ended than once they are driving confidently.
Interesting point - though "space cushion" is day 1 of drivers ed typically.
I find that the brake lights don't come on when you gently lift foot off accelerator. Regen really has to kick in for brake lights to come on. I started paying attention after first reading this thread. Carefully when people behind are too close
Yes, but ICE cars don't decelerate as quickly as a Tesla and they won't come to a complete stop without applying the brake.Thats basically how it works in every car out there.
It's the same as an ice car but different. I find other cars seem to come up closer to me with the X than even my standard civic
As far as regen, the brake lights don't come on even with full pedal release until the speed is down below 40 MPH. Try it next time you exit the free way.
Interesting. You must be braking harder/sooner in the X I guess? I haven't noticed any difference at all in the X vs our ICE car in terms of people coming up behind. I wonder if it's because you are using AP to brake, which tends to leave it later than I would when approaching slow traffic or junctions? Now I always switch AP off when I see slow traffic up ahead, brake manually and then switch it back once I get in line for stop/start crawling.
Folks have different views on AP setting...... but IMO, if you choose 7 you’d have more distance for car to stop, perhaps mitigating rear enders.
I have mine set on 7 all the time. It still sees slow moving traffic very late for my liking and then brakes hard. It's fine when following fast moving traffic which then slows down. The problem is when you are approaching a line of slow traffic at high speed, it simply can't see far enough ahead to react sensibly and bleed off some speed on initial approach. So I just switch out of AP in that situation and brake manually.
The other thing I don't like is when a car pulls out in front of you at high speed, AP tends to over-react and brake much harder than I would manually. It doesn't make the same flexible use of the gap to the car in front when braking as you would when driving manually. So that's another potential for getting rear ended I guess.
But overall I don't feel more or less vulnerable to being rear ended in the X than any other car. I think where you are driving is a much bigger factor and luckily in the UK it's not a major problem.
Okay did this test and my X is not like this at all. Lifting off completely from a steady 75 mph, brake lights come on as soon as it startst to slow (at around 73 mph). Tried the same at 60 mph and 50 mph with much the same result - brake lights come on as soon as the car decelerates. So either your car has different brake light settings (US vs UK?), has a fault, or perhaps you simply have regen set to "low" which would slow more like an ICE car when lifting off. Any other data points from other owners?
