Are you grandfathered in to an older agreement? I can not find anywhere in my NEM Agreement, nor on the PG&E website that states if you under produce for a calendar year that you will be paid the retail rate for any excess production during summer months. I definitely will not under produce for the year now, however, that can change once I get the Model 3, however, I have free charging at work, so I am hoping to add very little to my yearly usage. I am on TOU-A and not yet on the EV-TOU, as I am still waiting on Model 3 to be available. Is there a difference in in what you get paid for overproduction on the EV-TOU? Awesome if you get it, which it sounds like you do. Just trying to figure out if there is a way to get paid retail rate for any excess as well. Jealous of your profile picture too.
It looks like you don't understand the fundamentals yet. Net Metering is exactly that - the number of kWh you have consumed during each time period is totaled up and multiplied by the $/kWh rate for that period. It doesn't matter if the total kWh is positive or negative. Everything it totaled up to dollars for each billing period. The dollars are totaled up for the year. If your total dollars are positive, they go month by month and deduct any amount you have already paid in Minimum Charges on your normal bill. Then they will add your remaining True-Up energy charges to your normal bill. If your total True-Up dollars are negative for the year, but your kWh were positive for the year, the dollar credit balance is wiped out. If your dollars and kWh are both negative, then they take the negative kWh and multiply by ~$0.035/kWh and pay out your Net Surplus Compensation.
Here is an example of how the monthly calculation works. Sorry this table is overly complicated, but it is generalized for all rate plans. Schedule EV is simpler because it has no tiers. This is actually June/July 2013 usage data even though the rate calculation is the current Jan/Feb 2017 rates.
So, you can see (in the yellow shaded cells) that for the Summer-Peak period I generated 61.66kWh more than I used, in the Part-Peak period I generated 79.02kWh more than I used, but in the Off-Peak period I used 525.72kWh more than I generated. So, the dollar totals are in the lower right corner -$27.73 Peak, -$19.42 Part-Peak and +$62.10 for Off-Peak. Net $14.95 for a net of 385.04kWh which comes to $0.0388/kWh
This is for NEM 1.0. There would be additional "Non-Bypassable Charges" for NEM 2.0 customers. I don't have an example of a NBC calculation yet.
Here is the same usage data on E-TOU-A. E-TOU-B is $101.81. Please change your rate plan as soon as you start charging an EV during overnight hours.
