UCIBtheG
I've been hoping that the PowerWall can be set up to back up the whole breaker panel as you describe. I would never run my A/C along with my dryer, which (besides the EV) would be the two biggest power drainers. But, let's say I'm peak shaving during summertime with the A/C, TV, and some lights on. I then heat something up in the microwave and surpass the 5kW draw that the PowerWall 2 provides. What will happen? Would it pop some kind of breaker on the panel or PowerWall, or just pull the additional power needed from the grid? Or would it cause a voltage sag to everything running?If you can power-manage (as Generac calls it) the AC, dryer and oven circuits, you could do the whole breaker panel for most homes. It's an easier wiring job. Most homes only have 1-2kw load, or less, without those big devices. If solar is able to power during the day and it is big enough, you can go off grid carefull simply with a 15-30 kWh battery for days.
