My new wheel/tire setup, and tint.
Discussion in 'Model S: Interior & Exterior' started by johnmodels, Mar 7, 2013.
  1. johnmodels
    johnmodels Member
    SoCal
    #1 johnmodels, Mar 7, 2013
    I know I am opening myself up to attack, but I have just completed my baby and am open to your opinions!!!! Good or bad are welcome...
    Here is how it started: 85kw 19" stock wheels
    After "medium" ceramic tent all around.
    Wheels: front = Falken RT-7m 8.5" x 20" 38mm offset with 245/40 zr 20 Falken Azenis tires
    rear = Falken RT-7m 10" x 20" 38mm offset with 275/35 zr 20 Falken Azenis tires
    There is slightly more tire noise than the 19" stock tires. The feeling has changed A LOT! Very little sidewall flex which yields a much sportier feel. IMO this is how the car should be and probably similar to the 21's but not harsh. I noticed when I hit the accelerator with the 19"s I got some tire flex and rear "float" under load. Not now. No rubbing at all!!!!!
    I love it! I hope you do too!
    BTW I get 300% more looks now than I did when it was stock.
    John
  2. iamsohai
    iamsohai Member
    PNW
    Looking good! Got any side shots?
  3. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    Very nice choice.
  4. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    I think you probably put 245/40 R20 tires on the fronts. Using 50s would be quite big. And wouldn't be close the rear tire size at all.
  5. johnmodels
    johnmodels Member
    SoCal
    #5 johnmodels, Mar 7, 2013
    You are right. Typo... They are 40 series. Added pic of side of car.
  6. ElSupreme
    Atlanta, GA
    NP. I did a calc using your front tires, and was going to question/berate you for such a huge tire size differential, from stock. (and ask some question about how well they fit, because I would be amazed if something that big actually did fit) :biggrin: Then I checked using your rears, an realized no one would do something so horrible to a Model S they purchased. And alerted you so no one else would do the same.
  7. johnmodels
    johnmodels Member
    SoCal
    :redface: Busted me!!! You have an eye for detail. The diameter is almost the exact same as stock using these tire sizes. About 1% difference or unnoticeable....
  8. mnx
    mnx 2013 P85
    Ancaster, Canada
    So other than looking nicer, how does the car benefit from wider wheels + tires in the rear? Does it give you better grip on cornering or straightline acceleration?
  9. johnmodels
    johnmodels Member
    SoCal
    IMO and I'm not a race car driver, but I do own other high performance cars, the cornering is superior to factory 19"s. Little to no sidewall flex and more of a performance tread compound. Rear is less likely to swing out when cornering under acceleration. I think the car "feels" more solid than when I had the 19's.
    John
  10. mnx
    mnx 2013 P85
    Ancaster, Canada
    Thanks I would guess a lot of that has to do with the short sidewall on the 20's vs. the 19's and the tread compound like you mentioned. FWIW I did some googling on wider tires and found a rather good discussion here: Forzamotorsport.net Forums - Discussion: Pro's Con's of Wider Tires
  11. johnmodels
    johnmodels Member
    SoCal
    Great point, and great forum recommendation. I suspect that the efficiency has suffered a bit with the wider rear tires. FWIW the stock rear tires could not handle the power and I do not have the performance model. The TC kicks in and thats when the pavement is dry. I can only imagine what happens when wet. I reset the trip meter when I got the tires and will report in the future about efficiency changes. Weight is up too. Again this car weighs over 4500 pounds and even though I increased the unsprung weight I'm not sure if that negatively effected it much.
    john
  12. mnx
    mnx 2013 P85
    Ancaster, Canada
    I wonder if anyone will try skinner tires at some point??
    Something like this could be a good blend of performance and efficiency...
    MichelinPilot Super Sport in 225/45R19
    (4lbs lighter than stock tires and way better tire compound/grip)
  13. elektrikS
    elektrikS Member
    Issaquah, WA
    That is the exact setup I have been trying to create with Photoshop for weeks! Looks great!
  14. Benjam
    Benjam Member
    Phoenix, AZ
    Looks tight - great job and very distinct look. Now all you have to do is add headers and exhaust...oh wait, it's electric :eek:
  15. johnmodels
    johnmodels Member
    SoCal
    Don't forget the neon lights on the bottom, the thumping base you hear a mile away, supercharger, headers, mufflers, high flow cats...... Sorry, I got a little carried away!
  16. wycolo
    wycolo Active Member
    WA & WY
    If you can wear out a pair of rear tires without shredding these flimsy rims, then I will sigh a sigh of relief!! If its gonna happen it will probably be on your watch, but seems like you would be better able to handle the situation than an average driver would. To the others running non-Tesla rims: take it easy and let johnmodels do the heavy lifting, keep *your* TC = ON.
  17. tdelta1000
    tdelta1000 Active Member
    South Florida
    The new look is nice!!!!
