My Outdoor 240V Charging Outlet (photos attached)
Discussion in 'Model S: Battery & Charging' started by MrSniffer, Nov 22, 2012.
  1. MrSniffer
    MrSniffer Member
    Palo Alto, CA
    I needed to add an outdoor charging point for my Model S. The NEMA 14-50 socket is connected to the mains via conduit which enters from the bottom of the waterproof box. The Tesla charging cable exits through a slot cut in the the plastic. The slot (and box) is large enough for me to stow the working end ("nozzle?") in the closed box when I am off for a jaunt and plan on reconnecting when I return.
  2. spatterso911
    spatterso911 P100DL - Raven
    Rancho Cucamonga, CA
    Looks great!
  3. FlasherZ
    I like it. You may want to consider a stress-relief hook mounted on the back to support the loop on the cord, as the UMC's cord expects to be hanging down from a vertical receptacle.
  4. NigelM
    NigelM Recovering Member
    Northern Virginia
    Neat, although nobody round here would get away with that. (220 outlets have to be 4' above grade here)
  5. FlasherZ
    The proximity of the water tap to a non-GFCI protected outlet is potentially an issue (despite the fact that the UMC is GFCI-protected), the fact the outlet faces up is potentially an issue. I'd have to ask if THWN wire was used (it's required here because of wet location). There are a few other things that might result in it not passing inspection as well.
  6. MrSniffer
    MrSniffer Member
    Palo Alto, CA
    It was installed by a licensed and experienced electrician. These are all good observations. Esthetic tradeoffs prevail...just ask my wife!
  7. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    An interesting arrangement. Perhaps it would be better to have rotated the box 90 degrees counterclockwise, and attached the plug to the left side (so it's not facing up, but sideways)? That would also mean the UMC cord is only turning a 90 degree angle coming out the bottom.
  8. MrSniffer
    MrSniffer Member
    Palo Alto, CA
    The suggested orientation was definitely a strong contender; but that requires two bends in the conduit. One plus with the chosen orientation is that the only openings to the waterproofing are on the bottom surface, since rain generally comes from above.....
  9. Caloncho
    Caloncho LongerTelomeres?
    NewYork USA
    well disguised box! kind of low positioning maybe, but cool exterior charger, very convenient !
  10. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    The only part of your installation I would comment on is there are regulations for the outlet proximity to the water faucet. The concern is that there is a natural tendency to put your left hand on the water faucet when you are bending down to plug in the 14-50 plug. This provides a perfect ground for current to travel through your body. To be safe, make sure that you do not touch the water faucet while messing with the plug!
