My solution to lifting the parcel shelf lid automatically when the hatch is raised
Discussion in 'Model S: Interior & Exterior' started by artsci, Nov 8, 2013.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    Having experimented with a number of approaches for raising the hinged part of the parcel shelf when the rear hatch is opened I finally arrived at a solution that I think looks reasonably good, is easy to do, and works beautifully.
    The first challenge was finding something to attach to the edge of the parcel shelf that would look decent when hooked up and had a simple means of attaching thread linked to the top of the hatch. After a lot of searching I found this:
    Yes, it’s for a corset, but the black material and little steel loop attachment seem perfect for what I had in mind. I cut off a 2 1.5 inch sections. each with one loop, and glued them to the back of the hinged part of the shelf.
    I bought 100lb test woven nylon fishing line to attach the loop to a small screw on the top sides of the plastic surround for the rear hatch. The line is looped around the screw and the screw head tightened on the thread so it can’t come off.
    Then I threaded the lines to loops on the corset material glue to the backs of the hinged shelf part. But that wasn’t going to be satisfactory. As I often transport my dog in that space, and have to remove the parcel shelf when I do, I had to make the attachments easily removable, which meant finding a quick and simple way to disconnect the lines to the the parcel shelf. I puzzled over that for a while until realized that I had a few snap-in black plastic lanyard connections I had bought to hang the Tesla fob around my neck. So I added these to the lines near the corset material and voila. When I need to remove the shelf I unsnap each side. The lines then hang down out of the way.
  2. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    Nice. Better than some of the binder clip solutions I've seen (sorry, binder clip folks!).
  3. SamGarber
    SamGarber S85 "Whale Shark"
    Philadelphia
    Want :)
    I have forgotten to flip back the shelf 3 times now - so annoying when you realize this on the highway... This would solve that problem!
  4. wcalvin
    wcalvin Member
    Seattle WA USA
    Fish line thru hole in shelf, tie to light
  5. artsci
    artsci Sponsor
    Timonium, Maryland
    Should we do this as well next Saturday? I've got the stuff to get it done.
  6. SamGarber
    Philadelphia
    Yes please!
  7. artsci
    artsci Sponsor
    Timonium, Maryland
    O
    OK
  8. bradhs
    bradhs Member
    San Diego, CA
    Artsci, what kind of glue did you sue to attach the corset to the parcel shelf?
  9. artsci
    artsci Sponsor
    Timonium, Maryland
    High quality superglue, largely because it dries almost instantly and produces a very strong bond.
  10. bradhs
    bradhs Member
    San Diego, CA
    Following in artsci's footsteps, here's what I have so far.
    I plan to make this more permanent once I've had a chance to test different points to pull up the parcel shelf.
    I chose do grab install mine on the bottom section and have some of the double-sided tape attach to the thicker carpet area. This way if it pulls it will be much harder to rip the thinner material.
    Another thought I had was to drill a hole right through. Have you thought of doing it that way? We can then use something like this so that it lasts forever: HTS Systems thermoplastic polymer fastening challenges solved with Sharp-Sert® metal inserts from Yardley Products
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    I would advise you not to drill a hole. I did that in an earlier attempt and it made a mess of the edge. The parcel shelf material is very soft not of very good quality. As a result I now have two parcel shelves:)
