My two biggest problems with the cybertruck
Discussion in 'Cybertruck' started by jkeyser14, Nov 21, 2019.
  1. jkeyser14
    jkeyser14 Member
    Baltimore Area
    How do you load long objects like plywood or drywall without sliding them in from the rear amd damaging them? Normally you have a second helper and load it from the side. There's no way to side load anything with the current design.
    Also, how do you see out the front? The low slope of the windshield means the A-pillar will be huge/long. I have to imagine that will give very poor visibility out of the front.
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    #2 Tam, Nov 21, 2019
    I guess one on the bed and one on the ground.
    I don't think long is the problem because the X's is also long.
    The bigger the pillar, the more visual obstruction but I can't tell until I can see it in person.
  3. kaffine
    kaffine Member
    Las Vegas
    I always load plywood and drywall from the rear. If two people one on each side and slide it in often I don't have a second person in which case I lift it up onto the tailgate at then push it in. I don't reach over the bed to load plywood 2x4s maybe but not sheet goods.
    Then again the bed is only 6ft so not much use in hauling sheet goods.
    I also wonder how low it will go with the air suspension. I saw a truck at Lowes the other day that was sitting on the ground tailgate was maybe 3 inches about the ground when open. Would be easy to use a dolly to move appliances into the bed.
  4. Tam
    Visalia, CA
    Since CyberTruck has a built-in extendable ramp, I would think even with higher height, that should not be a problem should it?
  5. jsimon7777
    jsimon7777 Member
    Castro Valley
    There's a little corner window. Still lots of blocked vision.
    It's obviously not designed by a pickup owner. You'll have to climb into the bed a lot.
  6. kaffine
    kaffine Member
    Las Vegas
    That ramp looked a bit steep to try and pull a dolly up. Load an ATV that is powered easy but trying to load a 500 pound appliance I would prefer lower to the ground or a longer ramp. A huge improvement over the tailgates with the built in steps. Since it has air suspension might as well let it lower down. I don't expect and wouldn't want it to drop to the ground like the truck I saw the other day. I want the truck to be drivable with an airbag blown not comfortable but at least able to get to a safe place.
  7. Cory151
    Cory151 Member
    Here's my take. It's an electric pickup with 500+ miles off range. Its got a 240v outlet so I can plug my TIG welders directly into so I've already ordered two of them.
    • Like x 7
    • Disagree x 1
  8. alanbyvale
    alanbyvale Member
    Nottingham
    I think it will sell well but probably to the wrong people! It's not going to make the F150 owners change. The other issue is the safety aspect. Is it going to meet any safety standards as it has reverted back to 1930's standards of building it like a tank. Wouldn't fancy being hit by that.
  9. electracity
    electracity Active Member
    It's not made for loading plywood or drywall. It's a toy.
    • Disagree x 11
    • Like x 4
  10. renim
    renim Active Member
    Oz
    Its not a toy, its a work vehicle.
    I could easliy see Bhp, rio tinto etc buy thousands of these for 'light vehicle' work use.
    • Disagree x 1
  11. Dborn
    Dborn Confirmed
    Sydney, Australia
    Maybe extensive camera systems and side screens to eliminate the blind spots caused by the massive A pillar?
  12. Zybane
    Zybane Member
    Washington D.C.
    You actually think a large company that spent hundreds of millions of dollars designing a new vehicle went "oops, maybe we should have checked if it will meet safety standards"?
    • Like x 9
    • Helpful x 2
  13. Mrcarcrazy
    Mrcarcrazy Many Leather bound books.
    South Padre Island, Tx
    I wouldn’t want to be hit by it. But I’d be okay hitting a Camry in it....perspective is everything.
  14. deonb
    deonb Active Member
    Redmond, WA
    Imagine two CyberTrucks hitting each other. Cue sound of metal reverberating across to the next county. Boooooiiinnng!
    • Funny x 2
  15. Barklikeadog
    Barklikeadog Active Member
    PA
    I hope they add some mirrors... big mirrors. Drives me nuts when they put small car mirrors on a truck.
    There has to be a backup, a camera system isn't always going to work perfectly. It's going to get covered in slush and snow.
    • Disagree x 1
  16. Dazureus
    Dazureus Member
    Michigan
    The Model X has a simliar A pillar and I find that it does get in the way for some gradual left curves. It doesn't prevent me from staying in my lane since I just index the car off the right shoulder, but it does make it more difficult to see on-comming traffic.
  17. Tam
    Visalia, CA
    I am tired of using my former S, current X and 3 for loading things from Homedepot, so Cybertruck doesn't come fast enough for me!
    • Like x 9
  18. electracity
    I vote that cybertruck allows you to park right outside the HD contractors exit area. Wear black and have an attitude.
    • Funny x 7
  19. Ace Treadmore
    Ace Treadmore Member
    Denver
    More like the company that makes the safest cars in the world suddenly decides to drop the whole safety thing, lol...
    • Like x 6
    • Helpful x 2
  20. eye.surgeon
    eye.surgeon Active Member
    Highly likely that built-in extendable ramp is a prototype fantasy that will not make it to production. Given the strength requirements to support an ATV the tailgate would have be be 9-12 inches thick and weigh 150+ lbs. Notice it was nowhere to be found on the demo cars.
