Srsly. 2nd time in 9k miles.
No, just occasional Home Depot runs.Wow, not punny at all!!
Do you drive through a construction zone?
Damn... is this covered under warranty? Or do you have to buy a new tire/pay to get it fixed?[
Original tires so no warranty. I don't believe this is repairable since it's near the edge of the tire.
Michelin actually does have a warranty for OEM tires. Just no road hazard though. This one is pretty close to sidewall though so it may not be repairable.There is no warranty on any OEM tires from any manufacturer, other than the assurance that they will be somewhat round.
Usually, a puncture within 1" of the sidewall has iffy repair prospects.
A puncture in the sidewall itself will get flexed out of place, will not hold, and no shop will attempt to install one.
You can definitely try to find someone who will patch it properly (dismount the tire, insert a plug from the inside, mount and balance). But don't be too upset if it works itself loose over time.
a
For the individuals who are not well informed I forgot to add this:
Apparently if you have the Michelin’s on your car Michelin has an outstanding warranty that will cover your tires (even if they’re OEM) and give you treadwear coverage. Here are all the links:
Tire Warranty | Michelin Promise Plan
Please stop spreading incorrect information. Perhaps you should read the link. What you’re quoting is for their road hazard warranty as I’ve mentioned earlier. Keep reading and you’ll discover:FALSE.
Read your own link:
Do you work for Michelin, or something?
- "Original Equipment tires are excluded."
