  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Nano applications, Ceramic Window tint, Clear bra, Lighted T, K40 and Roger's Decals
I took my Model S into Moe @ GP a few weeks after i received it. Moe is known for his Renewal Services, Nano applications, Ceramic Window tint, and clear bra service. I further enhanced my Model S with a K40 installation and Rick’s (Artsci) LED back-lit T for the nose cone. Below is the blow by blow of what Moe did.
K40 Installation
Front and rear radar detector
Front and rear laser sensors
All wires are run through factory locations and are wrapped with a special mesh protective casing
They used the existing factory openings in the firewall to access interior cabin
Entire frunk was disassembled and reassembled. Looks as if nothing has ever happened
K40 master module, G5 Laser module, and speaker tucked away neat and safe
LED indicators before/after
Clear Bra
I opted for Moe’s advanced installation where he removed the entire bumper, remove the lights and all of the trim, so he perform a proper paint correction, then he re-installed and apply a nano coating to entire film surface
Making sure everything is back to working order
Proper cataloging assures that nothing was left behind and everything went back to factory spec. This is probably unique to GP and one of the reasons had them do the work.
Tint
They take extreme precautions to make sue they do not get water on anything.
Another unique aspect of the tint installation. Door panels are removed for a cleaner and more accurate installation. When installation was complete at GP I could roll windows down immediately
Rick’s Lighted "T"
My Finished Model S
If you are in California, it is worth the drive to see Moe and his team at Glistening Perfections 949. 355.4911.
Thank you Moe, this is the first Testimonial I can remember writing!! You guys deserve it..
I would also recommend having a Mobileye installed, it will make you a better and safer driver...
