Concentrating Solar Power thermal storage systemWhat is CSP storage?
https://www.energy.gov/eere/solar/articles/concentrating-solar-power-thermal-storage-system-basics
Here's a proposal by LA Dept Water and Power to turn Hoover Dam into hydro storage:Thanks. What did you think about the rebuttal to that Jacobson paper? Here’s some coverage:
Science friction: Researchers rebut 100 percent renewables proposal
This does not make sense to me at all, given the constraints of an intermittent, dammed river. Even classic pumped storage is quite difficult to do successfully.Here's a proposal by LA Dept Water and Power to turn Hoover Dam into hydro storage:
The $3 Billion Plan to Turn Hoover Dam Into a Giant Battery
It would make a HUGE battery.
I don't understand... "current inability to regulate dam flow"? AFAIK This is not a problem.This does not make sense to me at all, given the constraints of an intermittent, dammed river. Even classic pumped storage is quite difficult to do successfully.
As a guess, this sounds like a kludge to work around current inability to regulate dam flow.
Yeah ... that sentence barely made sense to me too, and I know what I mean.I don't understand... "current inability to regulate dam flow"?
Underwater reservoirs[edit]
In March 2017 the research project StEnSea (Storing Energy at Sea) announced their successful completion of a four-week test of a pumped storage underwater reservoir. In this configuration a hollow sphere submerged and anchored at great depth acts as the lower reservoir, while the upper reservoir is the enclosing body of water. Electricity is created when water is let in via a reversible turbine integrated into the sphere. During off-peak hours the turbine changes direction and pumps the water out again, using "surplus" electricity from the grid. The quantity of power created when water is let in grows proportionally to the height of the column of water above the sphere, in other words: the deeper the sphere is located, the more potential energy it can store, which can be transformed into electric power. On the other hand, pumping the water back out at greater depths also uses up more power, since the turbine-turned-pump must act on the same entire column of water.
As such the energy storage capacity of the submerged reservoir is not governed by the gravitational energy in the traditional sense, but rather by the vertical pressure variation.
While StEnSea's test took place at a depth of 100 m in the fresh water Lake Constance, the technology is foreseen to be used in salt water at greater depths. Since the submerged reservoir needs only a connecting electrical cable, the depth at which it can be employed is limited only by the depth at which the turbine can function, currently limited to 700 m. The challenge of designing salt water pumped storage in this underwater configuration brings a range of advantages:
A current commercial design featuring a sphere with an inner diameter of 30 m submerged to 700 m would correspond to a 20 MWh capacity which with a 5 MW turbine would lead to a 4-hour discharge time. An energy park with multiple such reservoirs would bring the storage cost to around a few eurocents per kWh with construction and equipment costs in the range €1,200-€1,400 per kW. To avoid excessive transmission cost and loss, the reservoirs should be placed off deep water coasts of densely populated areas, such as Norway, Spain, USA and Japan. With this limitation the concept would allow for worldwide electricity storage of close to 900 GWh.[44][45]
- No land area is required,
- No mechanical structure other than the electrical cable needs to span the distance of the potential energy difference,
- In the presence of sufficient seabed area multiple reservoirs can scale the storage capacity without limits,
- Should a reservoir collapse, the consequences would be limited apart from the loss of the reservoir itself,
- Evaporation from the upper reservoir has no effect on the energy conversion efficiency,
- Transmission of electricity between the reservoir and the grid can be established from a nearby offshore wind farm limiting transmission loss and obviating the need for onshore cabling permits.
I came across this underwater version of pumped storage in Wikipedia
I hope I was not misunderstood, the underwater pumped storage of off-shore wind sounds really clever, although I admit to not knowing any details.The idea that we can't make storage work given the dozens of options is far more absurd than the thought that we will figure it out...
Is a great way to increase [yet again, thanks Trump/Obama/Bush] US national debt - great for treasury bonds I guess ?? Only $3 billion and the pipe and cement companies would love the extra work. Just how many/much Tesla batteries would that buy? Probably cheaper AND faster to build and could be distributed to WHERE the actual electricity usage takes place [distributed vs centralized].Here's a proposal by LA Dept Water and Power to turn Hoover Dam into hydro storage:
The idea is that they can pump water from downstream back up into the dam using surplus electricity then at a later time, release it again to re-generate electricity when needed.already is a hydro [storage] electricity dam - color me confused
Except that the down-river water does not hang around in a reservoir until the sun is shining brightly and there is excess power on the grid.The idea is that they can pump water from downstream back up into the dam using surplus electricity then at a later time, release it again to re-generate electricity when needed.
This subject dovetails with my questions from a few months ago why large scale hydro is not used more in the evening hours when PV and wind are insufficient. I don't think anybody was quite sure but people suggested mandatory water release and contracts as possible answers. If the former then pumping back is not going to fly; and if the latter, changing the contracts will be a better and cheaper idea than back-pumping.
TFA says that they are using a downstream lake to draw water from to pump back up hill. Lake is kind of like a small downstream reservoir.Except that the down-river water does not hang around in a reservoir until the sun is shining brightly and there is excess power on the grid.
Maybe the scheme is a good idea, but I cannot understand it.
sorry you read my unedited post. I read the proposal then did the above post. You'd think I'd be mature enough to read before I post sadly it seems you'd be wrong. - sorry about that.The idea is that they can pump water from downstream back up into the dam using surplus electricity then at a later time, release it again to re-generate electricity when needed.
Yes, pumped storage has a long 10 year lead time and environmental effects. They say it will be cheaper than batteries but what about batteries 10 years from now? Distributed storage has advantages.sorry you read my unedited post. I read the proposal then did the above post. You'd think I'd be mature enough to read before I post sadly it seems you'd be wrong. - sorry about that.
Take away: I suspect Tesla battery much more reasonable.
Tesla battery projects seem to come in on time and at budget.
Tesla and PG&E are working on a massive ‘up to 1.1 GWh’ Powerpack battery system
How big a battery would $3 billion dollars buy? How about distributed batteries vs all in one place.
PS- the few fish left might not enjoy all this pumping of the river's water.
Like other alternative energies, the trick is to choose wisely based on location. Two projects in Australia, one of them in Tazmania look promising.They say it will be cheaper than batteries
The pumped storage system doesn't use water like agriculture, etc. It just moves it up hill then down.side note: Storing Colorado river water for a utility scale electric storage - who can think this is a good idea?
We could use more Colorado river water, not less - drought vs brown/black out? which would you choose?
What fish could survive? What would the water temperature become?
10 years to build? perhaps less than a nuclear reactor?
Flow batteries might well be cheaper for utility scale batteries:
Flow Batteries | Energy Storage Association
