nwdiver
Not sure what you're trying to argue.
That instead of using a failed utility as some kind of proof that large utilities can't work we look into why that large utility is broken... and fix it.
I believe all of the planes were grounded for years until they were fixed.I'm pretty sure we just let Boeing keep making their planes and the individual passengers just ride in the planes. Ultimately individuals don't have any power. So yeah, if the "we" in your sentence are individuals and community/groups; they've pretty much given up caring for flight and aerospace. "We" didn't do any fix.
Mega-corps and government-subsidized big-businesses own the consumer flight process. It's pretty much like what PG&E wants with energy where you live with what they cram in your face regardless if it kills you or not.
Not sure what you're trying to argue. There is no disaggregated airplane design or manufacturing to give consumers much choice. I saw some cool VTOL aircraft on StartEngine, but you know that's a lot of baloney.
I have no clue what we're even disagreeing about any more. Like what the heck. Can't we just agree that PG&E sucks and heat pumps are cool?
Until we actually elect some people who think PG&E is too big and needs to be knocked into pieces; it will continue to oppose any real/useful progress at re-purposing/re-inventing what the "Grid" is.
I don't know. PG&E has proven to be totally corrupt, greedy and incompetent. I don't think this private for-profit corporation which only seems interested in feathering its nest deserves to exist.Can we also agree that it would be better to fix PG&E than to 'knock it into pieces'?
A public owned (or government owned) corporation would be more responsive to consumers.
Of course the infrastructure needs to continue to exist, be maintained, and expandThat qualifies as a 'fix', it would still exist... just as a nationalized entity like BPA or TVA both of which work fine.
A few months ago, we started building our retirement home. It will be fully electric house (has the gas line run into the house just for back up and future resellability).
It will have a Tesla solar roof with several PWs. HVAC will be Mitsubishi heat pump system.
Found out that you can get heat pump pool water heater using inverter technology similar to Mitsubishi from Canada.
Here is what we getting Heat Pumps – Pool & Spa Cost - Arctic Heat Pumps
Done. We have 2 Rheem 80 gal hybrid water heaters.
Yep. Got a pair of Miele heat pump dryer, washer. I think the W1 model.You can even get a heat pump clothes dryer. Any modern heat pump system will use 1/4th the electricity as direct resistance heating.
I installed a Samsung heat pump dryer in my new house. Takes a bit longer to dry but works great.You can even get a heat pump clothes dryer. Any modern heat pump system will use 1/4th the electricity as direct resistance heating.
From where does it intake and exhaust? Intake from the house and exhaust outside?You can even get a heat pump clothes dryer. Any modern heat pump system will use 1/4th the electricity as direct resistance heating.
Jandy is an American heatpump I believe. It does not work well when temp drops below 40 F, as is the case with most heat pump. On the other hand, inverter HP that is used in cold weather countries like the Arctic model I posted above works well when it goes to -F.We are loving our Rheem 80g hybrid water heater. For the pool, our poolbuilder installed a Jandy heat pump. One additional benefit is it can cool the pool if it gets too warm in the summer. We've only done that once - ran it in chill mode overnight and it dropped a 25,000g pool a few degrees.
I've installed several Chiltrix air to water heat pumps and they work well below zero.Jandy is an American heatpump I believe. It does not work well when temp drops below 40 F, as is the case with most heat pump. On the other hand, inverter HP that is used in cold weather countries like the Arctic model I posted above works well when it goes to -F.
We will see but I think anytime we can use HP, it is a win for the environment.
