Nav on Mute
Discussion in 'Model 3' started by shiftkenny, Feb 22, 2021.
  1. shiftkenny
    shiftkenny Member
    San Diego
    I don't know if this has been posted, but does people's Nav mute even though the volume is saved to my profile at 50%. Seems like 90% of the time i start nav when first entering my car its on mute..
  2. mswlogo
    mswlogo Well-Known Member
    MA, NH
    No. Do you by chance have an iPhone? When phones connect to cars they try to sync up the volume controls. And it can have odd side effects. There is an option on iPhone to sync Ringer and Alerts with the Buttons (Volume) or not. Try flipping it off and set your ringer Volume there. The car syncs one them.
    I had the opposite problem on my Wifes Volt that it would turn the volume down on the phone notifications every time it connected to the car.
    I think other issues like your describe could happen. Android might have its own quirks too like this. It gets complicated. But I suspect something like that is happening.
    Try getting in your car without your phone and I bet it doesn’t change on you. Just a hunch.
  3. AZAV8R
    AZAV8R Member
    Arizona
    Happens to me all the time. Bug...
  4. DCsquared
    DCsquared Member
    Yep! Same issue for me.
  5. shiftkenny
    shiftkenny Member
    San Diego
    I have an android.. this is super annoying
  6. dgb62
    dgb62 Member
    Salem
    all the time. i've seen other threads on this, not aware of any solution. i also get wildly different volumes coming from the same source--for example, i often have waze on in the background on my phone for the alerts. if i'm listening to a podcast or music, also from my phone, the waze volume is insanely loud. it will correct if i adjust it while the alert is on, but it's jarring every time.
  7. Kat Jacks
    Kat Jacks Supporting Member
    Maine
    My volume also varies, but not as much as others have indicated. I quickly turn down the volume when I get in the car, then adjust it up depending on what I'm listening to.
  8. Gizmo35
    Gizmo35 Member
    San Diego, CA
    Yes this has been a problem of mine as well
  9. shiftkenny
    shiftkenny Member
    San Diego
    OK i'm going to put a service request lets what happens
  10. Hayden
    Hayden Active Member
    Belgium
    Same here.
  11. captain_sahaj
    captain_sahaj Member
    Atlanta/Singapore
    same problem here
  12. LionXng
    LionXng Member
    Virginia
    I used to have this problem until I realized while nav is talking the volume wheel will change nav volume. So I instinctively was turning down my music to hear nav but actually just turning down nav.
  13. shiftkenny
    shiftkenny Member
    San Diego
    yeah this was the case before.. user error then it became a software error after an update. i just dont recall which one
