Nav Serious Slowdown???
Discussion in 'Model S: User Interface' started by Chipper, Jan 29, 2016.
  1. Chipper
    Chipper Active Member
    Chattanooga, TN
    I used to be able to plug an address into the Model S Nav and have directions in about 10-15 seconds. Now, it takes more than a minute before the directions show up. Anyone else experiencing this? Are there any solutions or workarounds other than using my cell phone?
  2. Jeeps17
    Jeeps17 Cath Jockey in a P85
    Montreal, Canada
    Someone posted earlier this week that a center screen slowdown they had was resolved by deleting previously visited destinations in the "places" nav scroll-down list (he noted he had quite a few).
    Not sure this is what is affecting you, but you may want to give it a try.
  3. Chipper
    Chattanooga, TN
    Thanks. That would be a quick easy fix. I will give it a shot and report back.
  4. Chipper
    Chattanooga, TN
    h
    Worked like a CHAMP!!! Just cleared out over 1200 entries and it is back to lightning fast like the car itself. Thank you for your assistance!
  5. cinergi
    cinergi Active Member
    MA
    7.1 introduced this slowdown if you have lots of entries in the visited list. Can also cause other stuff to be slow like the reverse camera taking a while to pop up.
  6. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Good to know. Was having this issue as well. Thanks!
  7. alwaysru
    alwaysru Supporting Member
    Austin, Texas
    How do you go about quickly deleting all of them? I've got ~500 - and one at a time seems terrible.
  8. Chipper
    Chattanooga, TN
    Tap the x's faster. (Sorry, I could not resist.) There is only a one-at-a-time ability to remove them. I had over 2,000 entries so it took a while. But it was worth it to get the response times back.
  9. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Did you have music playing?
  10. Jeeps17
    Montreal, Canada
    My pleasure, glad it worked !
  11. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    More great Tesla software...
  12. cinergi
    MA
    I wonder if using the "reset to factory settings" button (or whatever it's called) would clear these. Probably easier to reconfigure the car the way you like it than delete that many entries.
  13. TaoJones
    TaoJones Beyond Driven
    The Americas
    Glad to hear of this workaround.
    The best the SvC could come up with, and they claim it was from Tesla Engineering, was to update the firmware (to *.56, which did not help), and to remove my USB sticks. Not a fix in any way.
    I will remove 1000 entries and see what happens.
  14. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    I cleared mine out today. Once you're in edit mode it's one tap per item, and they move so the next item is in the same spot as the one before. Just do a woodpecker on the X button and they go away pretty fast.
    I'm not sure if it helped anything. I didn't have much trouble in the first place, just a bit slow bringing up the reversing camera. I think it was faster after but it hasn't been consistent anyway.
