Navigation map plus and minus buttons gone
As I remember it the + and - buttons didn't fix the setting...it lasted for say 20-30 seconds then reverted to standard...same as the two finger pinch now. I stand to be corrected but I just don't remember it ever being fixed...?
Yep. On the last road trip this drove me crazy. And with a slow connection plus MCU1, the map would reset and zoom away before anything was even displayed at the location I had panned and zoomed to. I had to keep giving it little nudges just to keep the area of the map I wanted to see on screen. After 5 days I was just ranting every time I needed to work with the map. I became quite inventive with the fates I wished upon whomever was responsible.
Reactions: SteelClouds
Upvote 0
They WERE permanent. They were permanent for the road you set them for. On highways they expand out and local roads they zoom it. You can use the + - button to adjust the amount of zoom out and zoom in when the car get to those areas. The changes stick. I used it all the time.
I hope they bring back the auto zooms, don't care about the buttons as long as the pinch to zoom remembers like before.
Reactions: jsmay311
Upvote 0
Seems there are mixed opinions about this...some say it is fixed and other say it isn't. Some say it works when NOT using guidance...I don't know myself as I haven't tried it. Will do later today.
Upvote 0
They work when out of guidance. As long as you don't have 44.25.x, the auto zoom for highways and local roads should still work.
Reactions: TexasTezla
Upvote 0
