Navigation stuck on Palo Alto factory
Discussion in 'Model S' started by mecfire, Dec 22, 2016.
Tags:
  1. mecfire
    mecfire Member
    Milton, GA
    problem fixed
    • Disagree x 1
  2. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    zero context
    Maybe you could explain what the problem was, and how it got fixed, in case anyone else has a similar issue and could benefit from your experience?
  3. RScottyL
    RScottyL Member
    Irving, Texas
    I agree with the above poster!
    Even though you fixed your problem, don't delete your content as someone else may have this problem and need to figure out how to fix it!
  4. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    This happened to my car as well, if I am interpreting the cryptic title properly. When cars are tested at the factory, and then quickly loaded onto transporter trucks (especially lower deck where they do not see the sky), I think they lose GPS context and initialization. It then takes a "cold boot" satellite acquisition in the new home area to lock in the GPS. That took about 2 to 3 hours for my car after pick up.
  5. mecfire
    mecfire Member
    Milton, GA
    sorry, as the previous poster mentioned, when I got in the car this morning it was working properly so must have needed some time to initialize after we reset. Thanks for the input!
