Navigation System
To see multiple routes, I'd suggest using google maps to plan your trip, choose the appropriate path you want, then share it with the car directly. This obviously doesn't help if your going long distances through the SC network, but its pretty good at routing you (even the lower interior spec without satellite nav uses real time traffic when routing you).
As for extra favorites, if you tap on a location on the map, you should be able to tap a heart icon and add it to your favorites (including giving it a custom name). I believe you get access to this if you also do a search through nav, and then click on the destination when it figures the route.
There's also your recent list as well, which pops up when you click on the nav search bar. It keeps every destination you've previously been routed thru in there, for a good weekend two if not longer. This is also where you can click home, work, or favorites. And your favorites should also come up in your search, so if you remember what name you gave a destination, it much easier than going to a list and scrolling (if you have a lot of them).
Hope this helps.
Hope this helps.
Sharing from Google Maps to the Tesla doesn't share the route, just the end address.
