Navigation updated (after 2017.50.2)
Discussion in 'Model S: User Interface' started by nkightley, Dec 30, 2017.
  1. nkightley
    nkightley Member
    UK
    I received & installed the 2017.50.2 update on Christmas Eve.
    Then yesterday (29th Dec) I had a 'Navigation updated' message on the main screen (no new update).
    Does anyone know what was added?
    Presume the previous update then caused the nav to update OTA 4 days later?
  2. Ande
    Ande Member
    Norway
    Try to take a close look at the maps, maybe they're vector maps now...
  3. Duke-U
    Duke-U Member
    Tilburg, Netherlands
    Those are the Navigon map updates for 2017, runing on the small screen. Somewhere on the forum this has been discussed. No big deal apparently.
  4. msnow
    msnow Active Member
    SoCal
    Navigon database update. Happens about once per year. Sometimes you’ll notice subtle graphic changes on the dash screen too.
  5. bob_p
    bob_p Active Member
    Our 2017 S 100D had the yellow touchscreen box (likely adhesive between the membrane and the display) and came back from the Service Center after Tesla replaced the touchscreen - and likely the console processor.
    After the service, all settings were lost in the car - and they had loaded the latest 50.2 software - which should also have included the latest map data.
    And... As far as we can tell, we're still running on the same 2 year old US maps - with the same mapping errors. The navigation software still can't route to our 3 year old house...
    Since Tesla is likely going to shift to using their new navigation software, it would be surprising for them to be pushing out map updates to all cars right now - since the new software should be using different (and hopefully up-to-date) offline maps.
  6. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Who knows when the promised new navigation software is ready. In the meantime updated Navigon maps are welcome.
  7. jerry33
    Texas
    Map data is always in a separate upgrade, it's never included with an OTA release. The only way you know if the map data has been updated is a popup with "Map data updated" on it. There's no install procedure the way there is on OTA releases, it's all done in the background.
  8. bob_p
    bob_p Active Member
    If the Model 3's have the new nav software, and they're now delivering to real customers, it seems likely we'll see nav 2.0 on S/X relatively soon - and if that's the case, seems unlikely Tesla would do a fleet-wide S/X map update for a navigation system they are likely going to disable in the next few weeks/months.
  9. msnow
    msnow Active Member
    SoCal
    Sometimes there’s no pop up either in which case you have to email Tesla and ask if you’re on the latest db version.
