Mrbry's 12V battery problems are definitely a drag and he has my sympathy for the inconvenience.
While it is possible that the replacement 12v battery is defective, the symptoms suggest that there may also be a problem with a component related to recharging the 12v battery. Unfortunately, this also appears to be a problem that is not detected by Tesla's proactive monitoring software, perhaps because the component is marginal and fails only at low 12v battery voltage.
I would suggest confirming with Tesla that they have thoroughly examined the charging subsystem for the 12v battery to confirm or rule out this hypothesis. Please let us know what they say. I would be surprised if it is just the battery.
There is one on utube for nosecone cars.Has anyone made a video showing how to replace the 12V battery on a Model X?
Shouldn't that have been covered under warranty? Almost $500 for a battery replacement?
I'm sad it comes to this.I'm still using a C-tek smart charger on the car every night while parked in my garage, to keep the 12v recharge cycles off for about 1/3 to 1/2 of every day.
When I'm at work, I use UMC to charge the car off 120v outlet... which is enough to close the contactors (obviously) and fire up the Dc-to-Dc converter in the car.. which powers the 12v circuits keeping the load off the 12v battery as well so it doesn't cycle during the day. It also pays for my commute energy. That's another 8 hours of every day of no cycling.
It also doesn't cycle when you're driving for the same reason. So all the commute time, another hour of the day no cycling.
No 12v replacement yet on a September 2014 delivered car.
I was "expecting" near annual replacement of this part when I bought the car. Now I've reset my expectations to "maybe every 5 years" and wouldn't be totally surprised if I got 10 years out of it if I keep up the current practices.
FYI the C-tek was on the order of $200 ... so good investment.
I live in a "cold" climate which is also friendlier on lead/acid batteries. Arizona type heat is hard on them. So your mileage may vary.
482 CAD ~= 382 USD.
I did. They said they tag-teamed it and I believed them. Lawrence has changed their service model since I was there last and it was all-hands-on-deck.Still about 3 times too expensive. And Tesla should cover it for free. Plus, 1.5 hours of labor charge when it actually took 45 minutes? I'd be complaining.
I think this is the general practice in the "dealership" industry. The job pays X amount of time and if the mechanic can finish the job in shorter time, it benefits the mechanic. If you have an incompetent mechanic, they can spend 3hrs changing out your battery but will only get paid the 1.5hrs labor regardless.Still about 3 times too expensive. And Tesla should cover it for free. Plus, 1.5 hours of labor charge when it actually took 45 minutes? I'd be complaining.
my 12V battery was replaced after the warning came up at about 14 months / 15,000km, a couple months after the first annual service - no cost to me, the repair invoice says "Pay type: Warranty".I guess the 12v battery isn't covered under the warranty, but would have been covered under the annual service plan? That's my guess as I've never had to pay for battery replacement, but then I shelled out up front for the service plan.
