Just found out that my charging setup is not code compliant due to NEC 625.54. My licensed electrician wasn't even aware of the code change.
For those unaware, if you use the Mobile Connector with a NEMA 14-50 the breaker must be a GFCI breaker.
Also for anybody that currently uses the Mobile connector with a GFCI outlet; do you have issues with the breaker tripping?
