Hello all
I need some advice on where to start looking to track down the problem.
I have a 2019 SR+ with a little over 40M miles. The vast majority of my charging is on a NEMA 14-50 outlet at work using the original Mobile Connector and the proper adaptor. There is no damage to the cable or adaptor (at least that I know of). I also occasionally use a Supercharger (where I don't get any error messages). When I charge (when it is going correctly), I am getting the full 32A my car can accept at between 205-208V (7 kW) per the app (just my observation - I don't constantly monitor the app).
Occasionally, I get a notification on my phone that charging has been interrupted (with a time stamp and SOC). But it was infrequent enough that I did not worry about it.
But in the last month or so, I have now had 3-4 instances of discovering my car charging at only 16 amps. When I discover it, it always shows the same voltage (205-208V). I know today when I discovered it, I did NOT have an interruption notification (I just double-checked to ascertain). To correct it, I go out to unplug the cable going into the car re-plug it in. I generally feel as though I always firmly plug the car in, but of course, this could be the problem (not firmly seated enough). I see no signs of dirt or anything around/inside the plug. I do not have any third-party apps (such as Stats) installed at this time.
So, other than the inconvenience, is this a major problem where I should drop everything to get this fixed? How do I go about finding out if this is a car error or a supply issue?
Any tips are appreciated!
