Need canbus ID for controlling dome and footwell lights
I got a black interior and the 4 reading lamps are just not bright enough at night. I am adding a led dome light in the middle of the headiner (no pano roof) and want to control/ connect it with the driver reading lamp. I am ok for the electrical connection portion.
My goal is to install a physical button attached micro controller that would send CANBUS messages to turn on all reading lamps AND the footwell lamps at the same time as there doesn't seem to have a manual way to turn those on other than opening a door or parking the car.
So I am looking for canbus messages to control the interior lights. If haven't found them in the lists floating around.
thanks
I would attach an analyser to the body canbus and turn them on/off a few times recording the time you did it, then sift through the logs. Take a bit of time but shouldn't be too hard.
I've done this with BMS commands and found them without much trouble.
