Need front end body parts
Discussion in 'Model S' started by Tracking, Sep 22, 2017.
Tags:
  1. Tracking
    Tracking Member
    Virginia
    I am new to this forum so please forgive me if I make a faux pas. Other EV boards often feature parts wanted/for sale so I thought I would try here. Need a used nose (fenders, hood, rad support, headlights, bumper, etc.) for a 2015 Model S. Would consider upgrading to the restyled 2016+ design. Also, can anyone tell me which components might need to be replaced to complete the upgrade?
    Thanks!
  2. demundus
    demundus Member
    Oceanside, CA
    Tesla Parts for Sale
    Parts forum is there. You usually need to be quick for the things you want, provided they are undamaged. I have a rear bumper for sale, for instance... but i got lucky its basically unmolested. You'll never find a hood, they are like aluminum foil. Headlights will be rough cause the tabs are garbage and break super easy. Fenders are welded to the car, so you cant buy them from tesla, not the most fun procedure to install either. My rear QP for instance was basically ruined by the removal procedure, the rivet sections are crazy thin.
    good luck :)
  3. jelloslug
    jelloslug Active Member
    Greenville, SC
    The front fenders are not welded to the car.
  4. demundus
    demundus Member
    Oceanside, CA
    Lucky us! It felt like it was but I never got around to needing to take them off :)
  5. kort677
    kort677 Banned
    florida.
    search the threads, there are a few cars being parted out, maybe you'll get lucky and find what you need, if you can't find what you need going through tesla for oem parts may be your only option.
  6. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I have a front bumper left over from a facelift . $300 plus shipping. Includes Nose cone and trim.
  7. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Don't we all...
  8. Lasttoy
    Lasttoy Member
    St Augustine, Fl
    What's a facelift? My nose cone is nasty. 2013 S
  9. Tracking
    Tracking Member
    Virginia
    Thanks for reposting my OP here. Llord, did you do the facelift using just an aftermarket bumper cover, or using an OEM 2016+ part and additional parts? If the latter, did the 2016+ headlights plug in with the same connectors? What other parts are required?
  10. Tracking
    Tracking Member
    Virginia
    Thanks! Have found nearly everything, but of course I'm trying to be a smart shopper and make sure I get the right parts at reasonable prices, so I'm still looking. Have repaired broken headlight tabs on other cars before and would consider it for this car. I plan to keep it and enjoy it for many years and am wondering if someone on here has advice on doing very durable DIY headlight tabs repairs. Thanks again.
  11. Tracking
    Tracking Member
    Virginia
    Thanks, that's quite reasonable and if I don't do a facelift I'll probably see if you still have it.
  12. demundus
    demundus Member
    Oceanside, CA
    FWIW OEM hoods are 1100 unpainted. Mine is slightly bent from closing a screwdriver inside the hood... they are like paper! :(
  13. Lloyd
    San Luis Obispo, CA
    Look up unplugged performance. This is the one I used. I recommend waiting until my installation is completed. I will post a review. It looks like there is substantial modification and fitting to make this product fit properly. It does not come primed as most bumpers, just raw plastic.
