I am trying to figure out if the vibration I have in my 2021 Plaid is the typical shudder or something else. My 9/2021 delivered Plaid drove fine until it developed a vibration after a skidding incident on the highway at 3k miles in 4/2022. I was acceleration along a slight curve and the car lost traction for a bit and it almost slid in to the median barrier. At the same time it skid, I heard a sound and vibration that felt like a tire coming of the wheel in the front. I had 20" signature wheels with All weather pilots that were 2 months old.
I pulled over and the wheels looked fine, and driving was fine as well. I couldn't figure out what happened. The next few days after this incident I started noticing a vibration through the accelerator, floor of the car in the front, and through the yoke. There was a certain audible quality as well since I had non-foam tires.
I noticed it happening under acceleration only at any speed from 39+ mph, and it would disappear in track mode with power going to the rear wheels only. I had the wheels balanced twice to make sure this was not related to the wheels. They found one wheel lost balancing for some reason and didn't notice any damage to it.
I changed the wheels back to my 21" arachnids, and had them balanced. The vibration got slightly better, and less audible, but the vibration was still there.
I took it to Tesla in May and they kept the car for three weeks and gave it back to me stating they didn't notice anything, but they did tighten up the "bolts." I assume this was something on the shafts.
For the first week it vibrated less but got worse as I drove the car during Summer 22 with the
I am at a loss and don't know whether this is the shudder that everyone talks about in the Plaids or if it is something else. Any help would be greatly appreciated.
Doubt it. Try this thread:If it is cold grease at what temperature does the vibration go away?
Cold grease they say for the shudder under hard acceleration. I don't think this applies to the vibration under gentle acceleration.Cold grease in the halfshaft. Tesla knows it.
vibration comes if you put it in neutral and just roll also. Have nothing to do with acceleration etc.Cold grease they say for the shudder under hard acceleration. I don't think this applies to the vibration under gentle acceleration.
This is the first time I've heard someone else describe one of the (possibly 3 distinct????) vibrations my 04/2023 Model S Plaid has. I only have 250 miles on the car so haven't spent much time on the highway, but I think I've noticed something that feels like a low frequency buffeting / ear pressure thing except it is a consistent low frequency without the thunderous whacks if a rear window were to be left open. I sense this as low as 45 mph but need to try to correlate to a vibration in footwell (that is most noticeable to me in first few minutes going only 25 mph or so and feels like something is warming up). I'll try to do a little more analysis and see if I have 3 distinct vibrational issues, or just 2...Anyone else notice vibration at higher speeds in the Plaid?
I get a constant vibration/shake in steering wheel, seats, and footwell when driving 55-85mph. Peak intensity 65-70 mph. Can be seen in left mirror. Can be heard; sounds like wind buffeting if leaving window open. Vibrates regardless of accelerating, maintaining speed, or decelerating. Increases in frequency in relation to speed. Wheels rebalanced but issue persists.
Inspected all the wheels and they look fine.
Swapped wheels from side-to-side, but vibration still centered around front left of vehicle.
Thanks for the reference... I don't have shudder and certainly not yet experienced any abnormal wear. I have been in a couple of Performance Xs that had the shudder, and Tesla replaced parts under warranty for the owners in both cases. I have two much mellower vibration issues than the half-shaft-destroying shudder I've felt in Raven Performance X and P95D X. One issue at ~25 mph feels like a warmup / pump / condenser issue and only happens for a while... The other issue happens at a bit higher speed but feels much more like some air pressure / reverberation issue than anything mechanical.This has been the issue and resolution for those who have done it...
Alignment Kit 1 - Acceleration Shudder & Inner Tire Wear - Tesla Model X & S
Which rims are you running? Since I last posted I bought a set of 19in wheels from Ebay. This helped GREATLY.Thanks for the reference... I don't have shudder and certainly not yet experienced any abnormal wear. I have been in a couple of Performance Xs that had the shudder, and Tesla replaced parts under warranty for the owners in both cases. I have two much mellower vibration issues than the half-shaft-destroying shudder I've felt in Raven Performance X and P95D X. One issue at ~25 mph feels like a warmup / pump / condenser issue and only happens for a while... The other issue happens at a bit higher speed but feels much more like some air pressure / reverberation issue than anything mechanical.
Not sure if anyone posted this yet. Did you hit a big pot hole and the wheels are bent? Try getting your tires rebalanced. That’s what happened to my wheels. There are wheel shops that can fix bent alloys. Just look around and Google it. Good luck.I am trying to figure out if the vibration I have in my 2021 Plaid is the typical shudder or something else. My 9/2021 delivered Plaid drove fine until it developed a vibration after a skidding incident on the highway at 3k miles in 4/2022. I was acceleration along a slight curve and the car lost traction for a bit and it almost slid in to the median barrier. At the same time it skid, I heard a sound and vibration that felt like a tire coming of the wheel in the front. I had 20" signature wheels with All weather pilots that were 2 months old.
For the first week it vibrated less but got worse as I drove the car during Summer 22 with the 21" arachnids. I noticed the vibration got worse in hot weather, and when going uphill. It also only happens under acceleration, light or hard. During 90 deg days it felt almost like there was an axle hitting the floor of the car when accelerating hard. It felt like something was going to break. Once my 8 year old daughter was with me in the car and I had to accelerate hard, and she said she even felt the vibration through the floor in the rear passenger area.
Using track mode to send power only to the rear motors did not mitigate the vibration anymore. Now it vibrates consistently at 39mph+ when the car has been warmed up for at least 7-10minutes of travel.
I took the car in October and it started getting colder so the intensity of the vibration lessened. I let the SA drive the car home and keep it for a day and he comes back and tells me he figured it out. I was excited.
He says it is you lane departing avoidance causing it. I was just so frustrated but I played along. They just wasted my time.
I picked up the car and found the car damaged in a hit and run in the Tesla service center parking lot which was like throwing salt on my wounds. It was a major waste of time trying to figure out the plate of the person from the crappy 720P cameras.
Well when I took it home I unsurprisingly discovered that it was not the lane departure avoidance. The vibration is still there. As it got in to 50F the vibration is less, but now the car makes clunking noises when I turn the wheels all the way and reverse or go forward in any direction at slow speeds. Also the car's tires feel wobbly when on the highway at high speeds like it is getting pushed around.
Oh and the vibration is still there even in cold weather at any speed from 39mph, though less noticeable compared to the summer hot weather. Sometimes it is only noticeable since I know how butter smooth it felt before this all began.
It’s not the carbon wrapped rotor because this 40-45 MPH vibration is also common in the standard MS Long Range. I have a 2022 MSLR with this same issue.I still have the vibration around 40-45mph that other people mention. I don't think there's any way to get rid of that. It feels like a vibrator in the footwell, lol. I believe it's a characteristic of the carbon wrapped rotor inside the motor. To me, feels fast enough to be synced with the speed of the motor before gearbox reduces it 8x.
Yes, and I’m not fully convinced it made much of a difference, if anything.Have you updated to 2023.44.1?
Yes, I have 2023.44.1. I also have the Long Range, not the Plaid. There appears to be some question about whether or not this “fix” was applied to non-Plaids.I would double check that the update was successful. There's no doubt 2023.44.1 took care of the vibration experienced under very light acceleration in the 38 to 48 mph range. At least in my case, after several days of trying to re-create the vibration this particular vibration is no longer an issue.
