Need help: some key dimensions of the UMC
Discussion in 'Model S: Battery & Charging' started by artsci, Jan 23, 2013.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    I'm beginning work on my new curbside charging station and need a few key dimensions for the UMC prior to receiving may car or the spare UMC I've ordered.
    I need two dimensions:
    1. The length of the plug with the 14-50 adapter attached (not including the actual plug prongs). See the diagram below.
    2. The length of the short cable from the body of the UMC to the plug.
    Thanks!!
  2. jed-99aggie
    jed-99aggie Member
    I just took a quick measurement.
    For the "plug", I get: 4 3/4"
    For the short segment of cable up to the elbow in the plug, including the lighted box, i get: 22".
    I hope this helps. Good luck with your project. Be sure to post pictures of the finished product.
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    Thanks! Should have some photos in 3-4 weeks.
  4. dins95
    dins95 New Member
    Darien, CT
    Hi, I am new to the board and grateful for all the help and info provided here. I am taking delivery in a week or 2 and am trying to set up a 240V outlet on the outside of my house. I wanted to house it so it was protected from all the weather we have in CT while in use. Would anyone be able to confirm the dimensions above are correct so I can find a cover/housing deep enough to accept the plug while being covered. Thanks
  5. Princeton96
    Princeton96 Member
    Lafayette, CA
  6. dins95
    dins95 New Member
    Darien, CT
    Thanks, I have previously looked over those threads & they are helpful. However no luck so far finding an in-use cover that can work to fully protect the plug. Aside from putting the outlet on the bottom of the box like in one of the threads. I figure you need about 5.5" of clearance from the outlet face. Trying if i can find an alternative.
  7. Princeton96
    Princeton96 Member
    Lafayette, CA
    Yeah, I wasn't able to find one that fully covered the plug. The door on mine doesn't close all the way, but it does protect the plug from rain. When it rains, even very hard, no water gets on the plug or outlet. The cover acts as an umbrella and it closes enough so rain can't get in from the side.
  8. Chuck Lusin
    Chuck Lusin Chuck P10548 Jenny P10614
    Riverside, CA
    What is the thickness (width) of the cable. I want to start to design a bar to hold the cable in the garage. Thanks Chuck
  9. artsci
    artsci Sponsor
    Timonium, Maryland
    Figure about 9/16 - 5/8"
  10. Chuck Lusin
    Riverside, CA
    Great, thanks for the info, artsci!
  11. Alpha
    Alpha Member
    Earth
    I'm trying to plan my installation perfectly... Could someone please post the rest of the lengths? First two were answered earlier in this thread, can someone measure and post the rest below?
    * length of wall plug? 4 3/4"
    * length of short cable from wall plug to brick? 22"
    * length of brick? ___
    * length of long part of cable between brick and car plug? ___
    * length of car plug? ___
    I've heard conflicting reports that the total cable length is 20' or 18' - although I believe it's actually 20' because that's what the PDF from Tesla says...
    Thanks in advance...
  12. Alpha
    Alpha Member
    Earth
    Anyone? Even just knowing the length of the brick alone would help a lot... I'm estimating maybe 13", knowing the short cable length and looking at some photos...
  13. mcornwell
    mcornwell Active Member
    Brick is 7 3/16", I'll try to get the other measurements tonight...
  14. Alpha
    Alpha Member
    Earth
    Thanks. That's shorter than I thought...
