Hi there I have a 2021 model 3 LR. My plan is to use my stock 18" wheels for winter so im going to use the stock Michelin MXM4 tires onto a new set of wheels.
my question is that will Braelin BR14 fit the stock tires? here are the specs on the wheels. I don't know which offset to go with because the stock offset is +40 so does anyone have a recommendation by any chance? I will link the wheels at the bottom of the page thank you!
Part Number: | BR14-1880-65BT+35C641 |
Size: | 18x8"19x8.5"19x9.5"20x9" |
PCD: | 5x114.3 |
Offset: | +35 mm+45 mm |
Finish: | Satin Black Anthracite |
Bore: | 64.1 mm |
Seat: | 60° |
Construction Type: | Flow Formed |
Lip Size: | N/A |
Weight (lbs): | 19.40 lbs |
Load Rating: | 1543 lbs / 700 kg |
