Need More OBD Space For Harnesses
Radlaw
Charles
414
188
San Diego California
I have a 2018 Tesla Model 3. The OBD connectors are at the base of the back of the arm rest. There is a small space empty beneath the OBD and a removable cover over it. I have added some devices that require an additional harness to be attached to the OBD. When I had only 1 additional harness, it fit in it. Now I have 3 and there is not enought room to put them all in the space below the OBD and put the cover back on. Any ideas on how to relocate the harnesses and/or get a cover on or fabricate a cover for them?
It seems to me that there is an opportunity here for a product, albeit probably not a lot of demand. It appears to me that you have multiple Y harnesses in there, one for each OBD dongle? Those things are gawdawful bulky for the limited space available. It can be frustrating to get one in there, and you're trying for three?
CAN bus is a bus, just hang multiple devices on there. For the OBD dongles we actually need four wires: two for CAN, Ground, and +12V (the latter two are for providing power to the dongle). The harness splitters we use are just a way of tapping into the four wires. It seems to me somebody should just sell a wire harness that has multiple OBD connectors on it instead of one. That wouldn't make the available space bigger, but would reduce the bulk of what you're trying to jam in there, and the cost would just be a couple inches more wire plus additional connectors. Personally I would look into modifying a harness to just have three OBD connectors on it.
Reactions: Radlaw
Thank you for electronics 101 explanation. I appreciate it. One of the harnesses only has 2 wires. Should it have 4? The OBD connectors (dongles?) for the 2018 Tesla have 20 pins. What are theother 16 for?
For those of us who are not electronically inclined, please define:
1) CAN
2) Bus
3) Dongle
Thanks
PROBLEM SOLVED: I cut off about a 1/2" from the bottom of the cover. This allowed space for the cables to exit. I then tucked 1 and half harness in the space beneath the OBD housing and there was enough room for the other by placing them flat against the housing. The cover was put back on, with a with a little pressure and it snapped tightly. The modification is slightly noticable and can be covered by the rug. Perfect no, but OK considering the location.
