Need P85D alignment help
Discussion in 'Model S: Driving Dynamics' started by docgarner, May 21, 2016.
  1. docgarner
    docgarner Member
    Clearwater, FL
    Hey all. I just got a new set of ContiSilent 21s to replace my original Goodyear PS2s (just a hair over 10k miles to reach 3/32" tread left btw). Amazingly, my local service center only carries the 245, not the rear 265 so they told me I can only have the PS2s, and if I bought the ContiSilent they wouldn't install them - only tires bought at the service center. So now I'm at the shop and at my request they check the alignment and tell me it's off. But the only spec in their machine (an up to date EagleEye) is Model S: Air Suspension (SU01) / Performance Plus (SU02/SUPP) : 2012-14
    I've attached the alignment report.
    Are these the right alignment specs for a P85D?
    I tried calling the service center to at least to me if these guys were shooting for the right specs. To say they were unhelpful would be the understatement of the week. They wouldn't even tell me if the P85D alignment is different than the performance plus.
    Can anybody let me know if I'm wildly off base?
  2. Edmond
    Edmond Permanon
    Seattle
    Not bad, but not optimal. (and also not symmetrical) Your rear camber is surprisingly good.
    lolachampcar's recommended settings:
    Front set to tesla specs
    -0.70 Camber
    3.55 Caster
    -0.04 Toe
    Rear set as follows
    -1.10 Camber (fixed)
    0.15 Toe
    And both sides should be the same.
    • Disagree x 2
  3. sorka
    sorka Well-Known Member
    Merced, CA
    Not just not optimal. That is way messed up. Your front toe is a huge positive number i.e. your front wheels are pointing inwards. The front total toe should be slightly negative so that it becomes 0 when torque sleep kicks in and pulls the cars forward by it's front wheels only.
    The rear toe is hugely messed up. It should be between 0.30 and 0.50, not -.19. You will chew your tires up in no time. The rear camber is surprisingly good for not having your inner edge wear to cords, but it's aweful for handing and for fuel wh / mile(as is your front toe). Your front camber is also really bad for handling. Don't take any fast corners.
    Your right caster shows the right front wheel is pushed back more than it should be...probably from hitting curb.
    So it was on an alignment rack. Why wasn't the alignment done?
    Here's my P85D after alignment:
  4. Edmond
    Edmond Permanon
    Seattle
    Pretty emotional there, sorka.
    • Disagree x 2
  5. docgarner
    docgarner Member
    Clearwater, FL
    The alignment I showed in the opening question was before any adjustments were made. Here's the final I left the shop with. I'm not sure why they weren't able to adjust the front camber, but I understand the rear to be fixed. The car drives well and seems to hold true lines, so I'm not apt to spend another $200 at the Tesla Service center to have it done again unless you guys really think it'll make a huge difference. Thanks for posting back at me, BTW. It always freaks me out to have the car serviced by non-Tesla people.
  6. sorka
    Merced, CA
    The rear camber is not adjustable but the front is and they didn't adjust it. You should take it back and have them fix the front camber. It's dangerous to go around corners with any sort of speed with that much positive camber. As you load up the outside corner, the camber will go even more positive and you'll lose traction.
